Question about The Audio Players & Recorders
Hi I have Y50 BT headphone that work fine on BT but when I use a cable only the right hand works. Tried 2 different cables and same result. What could it be?
  • 2,005 Answers
Broken left speaker wire in the headphones
Posted on Mar 17, 2018
6ya staff
SOURCE:
micromaster
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
Anonymous
  • 3 Answers
SOURCE: Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
Posted on Jun 02, 2009
Anonymous
SOURCE: Sharp LC-26SH12U TV. Sound
My Sharp TV LC-26sh12U when at 50 is not good. After a hour or two I can hardly hear the program. What is happening?
Posted on Jul 09, 2009
Ty Price
  • 11967 Answers
SOURCE: canon eos 350 rebel xt doesn't recognize usb cable
Posted on Jun 30, 2010
satheeshkbos
  • 31 Answers
SOURCE: Sennheiser HD201 headphones. Left hand cable
there will be 2 wires in different colors inside the cable,
these wires are enamel coated and sennheiser has best quality coating over the wires, so soldering this could be a bit messy - this is the procedure to do so
first take out these wire leads out for about a centimeter from both the ends, try to loosen the leads and yo will find small clustered strands of fiber wound between the leads try to remove those fibers (only the visible ones) completely from both the ends of the exposed leads.
take a blade and try to wipe out the enamel coatings from the wires (make sure that the 2 leads does not touch each other after removing the enamel) now connect (solder) both the ends of the wire with their respective leads (eg. red with red or green with green as applicable) now you should be good to go
Please understand this is a delicate job and require atmost attention use cello tapes wherever applicable and tie knots at correct places to avoid further damages
Posted on Jan 30, 2011
Hi there!I have a 2GB Alba MP2200BUK and it was working perfectly fine until now, my computer can't read the device when I connect it using the USB cable. The notification doesn't even pop up like...
Have you tried using a different USB cable if so then it's most likely a device malfunction or the drivers are corrupted start with a different USB cable first
Dec 02, 2017 | Audio Players & Recorders
Hey there. I own a pair of Philips SHL8800s (great bass btw), and after 2 months of use, the left side stopped working. The right works great, as usual. I read Grubhead's post and tried to determine...
it's prob a loose wire inside. however i dont recommend you repair it at home. it's tedious work and it won't look good after. suggest you get it repaired.
Jul 12, 2011 | Audio Players & Recorders
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
320 GB Passport External HD recognized as drive F get i/0 error when try to access I have tried other usb ports with same results tried 2 different chords with same results Is this just toast?
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 24, 2011 | Western Digital Passport 320GB External...
Hi I bought a second hand fujitsu tv and Im trying to connect to bt vision because the connections are different i am using a pin to scart cable it works ok but there is no sound and the tv stays green , I...
I also have the same problem. I think maybe getting an electrician out is our best bet. The cables and connections are so confusing. Hopefully you manage to sort your tv out. It may be an s-video cable that you need. I think I may try that.
Emma
Feb 28, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
Sennheiser HD201 headphones. Left hand cable completely broken about 3" below earpiece, so only get sound from right hand side. Have tried connecting with connector block, which does not work. Would...
Jan 30, 2011 | Sennheiser HD 201 Consumer Headphones
Sennheiser Hd 205 headphones stopped working properly
the problem is the cable from one driver to the other suffers from fatigue due to the bending of the plastic frame as the headphone fits to your head, causing copper cables to disintegrate.
the solution is to take apart the headphones (mini and regular Phillips screwdriver ONLY required) and solder a new cable in. in my case i used a standard coaxial cable for replacement.
once you have split the end of the senheiser cable output from cup 1 into its two parts you need to attach it to the equivalent connections on cup 2 (which u also need to split, i suggest using a modeling knife)
the red wire is insulated with ceramic coating much the same way as an electromagnet winding, the other is standard copper. you must attach copper to copper red to red with YOUR OWN cable.
the most difficult part is removing the ceramic insulation coating on the red wire, which i removed with a blast from a cigarette lighter. simple.
problem is your cable probably will not fit in the slot designed for the previous cable so i drilled a small hole in the BACK of the cup (silver colored horse shoe shape) and ran the cable outside the plastic case. not pretty but it saved me £40 for 2 hours work, which is not bad.
i am a trained mechanical and electrical engineer so u can trust.
May 16, 2010 | Sennheiser HD 205 Professional Headphones
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Apr 23, 2010 | Beyerdynamic DT 100 Professional...
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
Top The Audio Players & Recorders Experts
Roy Cunningham
Level 1 Expert
Don Walper
Level 1 Expert
Larry Stiles
Larry Stiles
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
