Question about Kenmore Washing Machines
Kenmore Wash machine front loader 2004. S model 417.44142400. Drum bangs when it goes around When I twirl it it seems loose
  • Kenmore Master
  • 2,005 Answers
Your drum bearings have failed this unfortunately is a shop job
Posted on Mar 17, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Posted on Jul 15, 2008
Anonymous
  • 261 Answers
SOURCE: KENMORE ELITE SMART WASH QUIET PAK 4 FRONT LOADER,
Now this is a drain issue from the pump, clean out or check drain hose position to make sure hose isnt in water. Front loader right? kick panel under door has two screws, 1/4 or Torx T20 will remove them. You will see a clean out screw handle that holds junk. Use a trash bag wrapped around the clean out to catch water and debris..
Posted on Oct 23, 2008
Harjeet Singh
  • 109 Answers
SOURCE: front loader making loud noise with spin cycle
i have the same problem as urs. i open the whole drum myself and replaced the rear bearing. but the actual problem is the bearing housing is loose in plastic drum. so only drum needs to be replaced.
Posted on Oct 23, 2009
Anonymous
  • 572 Answers
SOURCE: loose inner drum
your bearing is gone. needs a new tub assembly. its pricy
Posted on Feb 05, 2010
Anonymous
  • 256 Answers
SOURCE: Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Posted on Feb 22, 2010
My washing machine tub seems real loose. It starts banging on the sides when starting to spin. What causes that?
Hi Steve, This is usually caused by an uneven load. For instance, If you have a bath towel in with some shirts or tea towels, the bath towel absorbes more water than the tea towels, thus making an uneven load.
My wife tends to wash slippers in a pillow case with nothing else in the washer, and the drum will bang against the side.
Hope this helps
Kind regards
David
Nov 10, 2017 | Washing Machines
Bosch ingfront loader inner drum banging around in spin cycle seems to be loose found tiny white wheel underneath has it come off something inside?
The machine needs to be properly balanced for it to be free of vibration also correct weight of clothing inserted would help obvious that the weel needs repair meantime try balancing the machine.
Sep 16, 2017 | Bosch Washing Machines
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Washer is louder than normal The drum seems to
the bearing assembly is beginning to fail.
requires an overhaul.
this problem is far too common with Kenmore and frigidaire front loaders
Mar 24, 2009 | Kenmore 43042 Front Load Washer
Kenmore front laoder washer with loose wash basket
Highly likely that either your bearings or spider arm has gone out, this is no easy fix. You can 'search' above or click on 'troubleshooting' in blue to browse
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Loud banging on spin cycle frigidare washing machine model no. fws235rft2
If this is a front loader this is a common problem. Unfortunately, it is also a very extensive project (about 8 hours). The tripod supports that attache the drum to the center spindle commonly break. The remedy is to replace both the front and rear tub, and the basket as well. It is also recommended that you replace the drain pump as well. Generally, they will cover the parts (not including the drain pump) under warranty but the labor will be a customer pay.
Oct 19, 2008 | Frigidaire Washing Machines
Washing Machines Logo
49 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
