Question about Apple iPad Tablets & eReaders
I have sound on my I-pad, but no light or picture
    Sergeant:
  • 386 Answers
Try and update software or factory reset but take iCloud off 1st and back it up to iCloud before you factory reset
Posted on Mar 18, 2018
6ya staff
SOURCE:
Ipad mini A1432, I changed the motherboard, display lights without light
You probably know this as you are able to replace a motherboard. The question is confusing. It sounds to me as though your saying your display light either stays on or comes on randomly, this is either a fault in the wiring or the soldering. You will probably have to go back inside the pad.
Mar 19, 2015 | Apple iPad Mini
No sound on my I pad even though it is turned on.
did you check the SETTINGS/Sound and General?
Oct 16, 2014 | Apple iPad 2
How do I turn off the touch tone on the key pad?
Go to settings.
Language and input.
Keyboard and input methods.
If google keyboard is your default, tap on the settings image.
Under General, there is an option called "Sound on keypress".
If checked, un check it and the sound will disappear.....
Sep 18, 2014 | Dell Venue 7 or 8 Tablet in Black
No sound on my asus transformer eee pad
I have an Asus Transformer EeePad also. I have a sound control button on the outside edge, upper left. Press the top part of it for up, and the bottom end of the button for down.
Otherwise, go to "settings" "sound" "volumes" . There should be a list of 3 items, "Music,video games etc" "Notifications" "Alarms". Each one has a sliding scale of sound. You can slide the volume of each one individually with your finger, then touch "OK". I hope this is of some use to you.
Mar 14, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
I Pad 2 - how to delete picture from a folder?
tap on the picture in question to view it, there should be a trash can on the bottom bar, just tap it and youre done
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Jun 02, 2012 | Apple iPad 2
How do you remove a single picture from the i pad?
You go into you photo's wich is located at the homepage of you Ipad. Second, you find the picture you wan't to delete. Third, you press the button that looks like a trash can.
Jan 03, 2011 | Tablets & eReaders
Tablets & eReaders Logo
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
