Computers & Internet Logo
G
GERALD Posted on Mar 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FORGOT MY HUAWEI B315-3BB5 BROADBAND PASSWORD. HOW DO I RESET THE PASSWORD?
Joseph Wright
Level 3:
  • Huawei Master 1,729 Answers
  • Posted on Mar 18, 2018
Joseph Wright
Huawei Master
Level 3:
Answers
1729
Questions
Helped
455245
Points
5127
5 Related Answers
Anonymous
  • 1851 Answers
  • Posted on Dec 05, 2010
SOURCE: forgot my password for linksys wireless-G
You can use the reset button at the back of the router. Keep in mind that this will also reset any other configuration you have made at the router. The credentials and the ip for the router will come back to the defaults (192.168.1.1, admin, admin or none or 1234)
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
mobil master
Computer Repairing
  • 14641 Answers
  • Posted on Jul 29, 2012
SOURCE: forgot password on HuAWEI HB5K1H
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Anonymous
  • 20 Answers
  • Posted on Aug 12, 2012
SOURCE: how do i reset my huawei hb4j1h i forgot the password
Have you tried holding down F11 during its boot up?
Anonymous
  • 22 Answers
  • Posted on Oct 22, 2012
SOURCE: I have a cricket huawei HB 5K 1 H it's a muave music 2 phone I forgot the password n the gmail account I have linked to the phone how do I reset it so the lock is off?
You can ask for the gmail account handle. Sometimes it will show up in the phone.. your gmail account address. If you look under my accounts info, you can find out the google account you have...
If not, you can use a computer and request your username..
jaymee kelly
  • Posted on Jan 17, 2014
SOURCE: forgot my screen lock password for my huawei u8350
I have the same problem forgot my password for my phone i have the imei code can u help
I don't have username and password for E8231s-2 modem
Security checklist for Huawei E8231s-1 router
To login to Huawei E8231s-1 router and change the network name and password,
  1. Start with opening your favorite browser,then in the address bar enter the IP Address http://192.168.8.1,
  2. You will now be taken to the login page where you can enter the default username: admin and password: admin
  3. Change Huawei E8231s-1 default Login and Password or reset it if you dont remember
  4. Change Huawei E8231s-1 default Wifi name (SSID) / Password.Continue reading for detailed step-by-step instructions
1.Open Huawei E8231s-1 Router IP Address Huawei E8231s-1Router Internal IP Address: http://192.168.8.1OPEN LINK
(Remember you must be at home and connected to home wifi to do this) 2.Login to the Huawei E8231s-1 Router You will now be taken to the login page where you can enter default username: admin and password: admin to complete the login process (You can simply use the copy-paste below). Voila! You are now logged in!
Default username for Huawei E8231s-1: admin VISIT MODEMLY FORUM Huawei E8231s-1 router login issues:
Huawei E8231s-1 Password Doesn't Work
Passwords find a way to not work! Or, in most cases, users find a way to forget them! In either case, look up the "How to Reset the Huawei E8231s-1 Router to Default Settings" section below
Forgot Password to Huawei E8231s-1 Router
Incase if you have changed the default username and password of Huawei E8231s-1 and forgot it, Please see "How to Reset the Huawei E8231s-1 Router To Default Settings" section below
Incase if you have changed the default username and password of Huawei E8231s-1 and forgot it, It's more like magic, I'd say! Press the reset button with a pin or something that gets through the tiny hole, and hold it for about 15 seconds! (till you see all lights flickering) Your Huawei E8231s-1 router shall be reset in no time, and you can start from step 1 in this guide to set it back up How to boost Huawei E8231s-1 Wifi and overcome connectivity issues:
1.Place the Huawei E8231s-1 in a perfect spot
The perfect spot does it all; be it romance or your router! To avail the best signal and network connectivity, make sure you keep your Huawei E8231s-1 router visibly and not facing the wall or behind the curtains
2.Find a Good Wireless Channel Instead of Auto on your Huawei E8231s-1 router
Auto channels might fail you once in a while; believe that you're smarter than the Huawei router! Find a seamless wireless channel instead of what the router finds automatically. This would ensure that your signal does not interfere with that of your neighbors.
If you're running a Windows-based PC, you can see what channels neighboring Wi-Fi networks are using.
-Press Start > type "cmd". Open Command prompt
-In command prompt type netsh wlan show all
You will see a list of all wireless networks and the channels being used in your vicinity. instead of using "Auto" for the control channel, Pick the channel that has the lowest interference
3.Check the frequency of Huawei E8231s-1
Check If Huawei E8231s-1 has dual-band, the more commonly used band would be 2.4GHz; however, switching to 5GHz would bring out better results! It depends on your device though; if you're running an old lad, you might have to switch back to the conventional.
4.Hardwire gaming consoles / media streamers into your Huawei E8231s-1 instead of wifi
Gaming consoles/media streamers work better when connected through Ethernet cable of Huawei E8231s-1; in fact, as you might not be moving your TV all over the house, why connect it to the Wi-Fi at all? The gaming consoles / video streaming devices flood the network with data. This means that if possible, you should consider hardwire (using Ethernet cable) the devices that tend to consume a lot of bandwidth. Although this can sort of defeat the purpose of having wireless network, but it can actually help your overall network speed of Huawei E8231s-1 if you can hardwire the bandwidth hogs.
5. Reboot Huawei E8231s-1 on a schedule
Here is something important to note! On schedule, folks, reboot your Huawei E8231s-1 router! Though routers are built to constantly be running at all times, simple tweak like regular power cycling (a fancy way of saying unplugging the power cord and shoving it back up) helps with most issues. Rebooting your Huawei E8231s-1 can fix Internet connection problems, improve slow moving connections and resolve wireless issues altogether. Try unplugging your Huawei modem on a quarterly basis to stay proactive (Never reset, always reboot modem)
I forgot my username and password of my huawei router how can i reset it again?
Which model is it? Difficult to guess which you have. There are free online manual that show how to reset, if you provide the model number using the Comment menu.
Some routers show a default username and password pasted on the bottom of the router.
After a reset, for many Huawei routers, the password is a default of either admin or 3bb and the username is admin.
1helpful
2answers
2answers
I forgot my password to connect to the driver port Huawei E5832... when it open, i was typing "admin' for the password, but i remember that once i've changed the password... but i totally forgot the...
Not in English, but the video shows you how to factory reset it. This will clear all settings and will default the admin user and password to the original defaults before you changed them.
1helpful
Forgot router password
there is a restore button on the back, this will reset to factory settings;
username: admin
Password: admin
2answers
Reset password
Please help me out i forgot my pattern and they are asking me to sign in and i have forgot my emailaddress and password please help
Forgot password on my huawei U7519 wind phone need reset code
i forgot my input password on my huawel g7105
Jan 02, 2012 • Cell Phones
Top Huawei Computers & Internet Experts
Ngoro
john h
Are you a Huawei Computer and Internet Expert? Answer questions, earn points and help others
