If you bought a second-hand iPhone/iPad stuck on the activation lock screen and don't know the previously used Apple ID and password, iMyFone iBypasser can help you activate iPhone/iPad without Apple ID. This excellent tool came out in 2020 and has helped many users who reset their own iPads without logging out the previously used Apple ID.
SOURCE: how do I unlock a locked up ipad?
If you've got a locked up iPad app or otherwise misbehaving iPad, and
want to reboot / reset your iPad, simply hold the sleep and home
buttons together until the iPad restarts.
You'll see the shutoff slider come up first, but just keep holding.
The screen will go blank and the Apple logo will reappear as the iPad
reboots.
Note: this does not reset any data on your iPad. This is just a restart, equivalent to rebooting your computer.
SOURCE: Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
If iOS 7 is installed on the device then this is a built-in security measure against theft to prevent a thief from erasing content and using as new. You will need to get in touch with the original owners.
SOURCE: i forgot my ipad code
If you have an iPad with iOS 7, you can't open the iPad. After you put in the wrong pass code 3 times, you only can unlock the iPad with the correct password, belonging to the Apple ID from what only a part is shown on the screen. If you don't have the passcode nor the password Apple assumes you are not the legal owner, and you can't use the iPad anymore. If you goto an Apple store and take your iPad and the invoice with you and some ID, so you can prove you are the owner, perhaps they can help. But if you can't prove the iPad is yours, don't go there, they will not help.
SOURCE: how to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
