Beeman 1024 Takedown Rifle, Scope, Rings & Case air rifle Logo
A
Anonymous Posted on Mar 19, 2018
Why does my air rifles leak air when I break the barrel of my weihrauch 0-97634
2answers
Where can I get Weihrauch HW100 air rifle filler probes or seals
Sorry we have locator services here, one reason we have no way to know where you are on this big blue globe.
Jun 18, 2017 • Optics
How do I separate a barrell from the action on a Weihrauch HW77 air rifle?
Crack the weld holding the barrel block to the cylinder split them apart then machine down the the opposite side to the pin end you see as it doesn't go the whole way through and drive out the pin
Then heat up block to release locktite and drive barrel out
Also the barrel is splined into the block so twisting won't work
Mar 01, 2015 • Optics
How do tighten / secure the barrel to the stock of my Beeman air rifle R9
It is a break barrel and if you secure it to the stock how will you cock it
Weihrauch air rifle will not ****.
Sounds like your sear is broken.
Mar 13, 2014 • Optics
2helpful
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
Pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Co2 leaks from chamber on crossman modle400 rifle how do i fix it
Check thare is a rubber o ring missing or broken in the air chamber
1helpful
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Top Beeman Optics Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Beeman Optic Expert? Answer questions, earn points and help others
