SOURCE: massey ferguson 3655
sounds like the seals are gone on the 4wd shaft, it takes oil pressure to keep the 4wd off, but if the seals are worn the all passes through and the 4wd will not dissingage, you will need a experianced michanic
SOURCE: Operator's manual for a Massey Ferguson 65 tractor
Go to google search engine and type in your tractor most of the time it will give you lots of web sites to look at.
SOURCE: no fuel to injector I have diesel to the injector pump
Is it a timed pump?
Testimonial: "even if out of timing I shoud have fuel pumping to the enjectors ,correct?"
SOURCE: What kind of oil goes in a Massey Ferguson Tractor
What model tractor - MF130/135 diesel takes 10/30 not gear oil for transmission/hydraulics
SOURCE: MF Tractor 265 diesel engine fuel problems.
I ran into the same problem and found the line to the tank was clogged, take your line loose and see if your fuel flows freely if not blow some air from a compressor back up the line and into the tank. Hope this helpls
