Car Audio & Video Logo
Nick Crow Posted on Mar 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony xplod xm 2165 1000 way max amp keeps shutting off or going into protection mode. How do I stop that?
Anesh Vassan
Level 2:
Habit-Forming:
Scholar:
  • Expert 71 Answers
  • Posted on Mar 09, 2019
Anesh Vassan
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
71
Questions
0
Helped
32718
Points
123
Hi nick, there can be many causes for this fault.
1. your speakers or speaker cables are faulty, then this problem will come up.
2. your installation is done incorrectly, or with the wrong gauge of power cables can cause this problem.
3. your vehicle battery could be weak.
4. you could have an internal problem with the amp only, which needs repairs.
cheers.
5 Related Answers
A
Anonymous
  • Posted on Aug 14, 2007
SOURCE: Sony Xplod Car Audio Amplifier
check your ground cable and make sure it is making a good connection because sometimes this does it
Anonymous
  • 5 Answers
  • Posted on Jan 18, 2008
SOURCE: sony xplod xm-554zr amp
try disconecting ur battary for 2 min and try it again
Anonymous
  • Posted on Sep 22, 2008
SOURCE: sony xm
internal heat capacitor or even a bad connection indside amp is bad giving you a hi output load wich the amp has an auto matic sensor to send it into this offset you speak of so it does not burn up
Anonymous
  • 18 Answers
  • Posted on May 27, 2009
SOURCE: sony xplod amp(XM-1652Z ) power/protect light
if your amp is overheating your sub is needing to much power that the amp doesnt have.
if its cutting out and the red light comes on you need to check the wiring. nothing not even the tinyest speaker wires can be touching.
proper wiring would be your best bet.
but i would upgrade amps.
cheap bang isnt reliable.
loft404
loft404
  • 11 Answers
  • Posted on Jun 17, 2009
SOURCE: Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
1helpful
2answers
My sony xplod 1200 whatt amps red light keeps coming on all the wires are good when it gos to hit it gos red
check your ohm load on the sub and see if your amp can do the same, That is why every time it shuts off into protection mode. Check your gain level on the amp to this is not a volume knob for your amp, It is to get both the amp and cd player on the same page. Hope this was helpfull
Sony xm gtx1852 amp new and worked for 1 day now is in protect mode even with nothing hooked up but the remote and power and ground.
meter the power side of the amp. sometimes the amp will go into protect if it doesnt have power. if power and remote and ground are good the amp is probably bad.
1helpful
Wont stop going in to power protect mode
Hi, does it still do it with speaker disconected?
1helpful
Xplod amp will not get off of power protection mode
if the protect light stays on the amp is blown or has flawed components and is only repairable by expirenced sony tech
Sony xplod amp(XM-1652Z ) power/protect light
Protection Light Comes on
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
2helpful
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Sony Xplod 1000W workign strangely
need a bigger gauge hot wire going to your amp ,maybe a battery cap. amp isnt getting enough power to perform so it cuting out.
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
