Question about Dyson Vacuums
How do I remove the red top on my Dyson V6 in order to clean the filter.
The cleaner keeps pulsating. I have looked into the parts, cleaned the roller and it still keeps pulsating. I cannot remove the filter to see if it is clogged. How do I do it?
  • Dyson Master
  • 18,429 Answers
Posted on Mar 27, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Posted on Aug 09, 2008
Anonymous
  • 7 Answers
SOURCE: removing the filter on Dyson DC07
on the 07 model it is on the right side push clip and pull inside will be a foam filter wash and dry
Posted on Dec 04, 2008
Anonymous
SOURCE: Motor overheating
There is a filter on top of the motor as well. You will need to remove the plastic cover on top of the motor with a small screwdriver or other flat blade. On the front, you push in the clip and pull up ont he cover. On each side of the cover there is another clip - to pop those you put your flat blade into the angled tab and slide it around to the clip until it pops. Gently or you'll break the tab. Once the cover is off there is a purple tab in the center pull up and you will pull the HEPA motor filter out - similar in shape and size to the side, washable, filters. Clean or replace that.
Posted on Dec 14, 2008
rustysheriff
Tony Groves
  • 344 Answers
SOURCE: Dyson cleaner keeps cutting out, no blockage found, filter clean.
1. Check the on/off button these can also be troublesome and if you've stood on the cable once or twice you could have a break in the wire and it's shorting, check by turning on and wiggle cable around where it enters machine.
2. Faulty thermocouple, it is held in a white plastic housing screwed with one T15 torx screw to the motor housing. You could replace it but I just shorted mine with some wire and it hasn't failed since and more importantly not caught fire yet!
Posted on May 28, 2009
Vacuum Guru
Alec Nelson
  • 78 Answers
SOURCE: Dyson DC05 top filter keeps clogging even
Hi there VacuumGuru for Vacuumspot.com.au. I would say that you are missing a part out of the vacuum dirt container. There is supposed to be a part a bit like an upside down funnel with a rubber seal on the end of it. Without this dirt will go straight to your filter. If you need any vacuum cleaner parts just go to Vacuumspot.com.au.
If you think this is a good solution please rank it!.
Regards Guru
Posted on Oct 16, 2010
Have 1 year old hand held v6 motorhead. When pressing the trigger to start. The unit surges on and off repeatedly on a 1 second pulse. How do this get corrected
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 04, 2017 | Dyson V6 Motor Head Cordless Vacuum
I have a dyson V6 Mot?rhead model Ju4-us-GBR7075 My machine when I push the power button the machine stops and goes
Ava B.
Jan 21, 2017 | Dyson V6 Motor Head Cordless Vacuum
My Dyson V6 started suction and motor pulsated instead of staying on. Filter cleaned - nothing blocking wand....help
Ava B.
Jan 07, 2017 | Dyson Vacuums
My dyson v6 animal surges when I push the button, the roller goes around then stops after about 4 seconds.PX6-us-HEA2023A, I put my manual away some where safe, I'm sure ill find it. Dec 2016
Ava B.
Jan 04, 2017 | Dyson V6 Animal Bagless Cordless Stick Vac
My cordless v6 vacuum is pulsing and not steadily running
Ava B.
Dec 28, 2016 | Dyson Vacuums
My Dyson v6 motorhead vacuuem shuts off intermitently. How do I fix this
There are a number of reasons why your Dyson cleaner shuts off intermittently. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
Ava B.
Dec 17, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
My Dyson V6 absolute is pulsating when I pull the trigger. I have cleaned the canister and checked for obstructions. I also cleaned the top filter.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
Ava B.
Nov 28, 2016 | Dyson V6 Absolute Bagless Cordless Hand...
I have a Dyson V6 Slim about a year old. It's stopping and starting - not continuous power. I have cleaned the brush the canister and the filter and it's still not working right. Help!!!!
Ava B.
Nov 28, 2016 | Dyson Vacuums
Dyson V6 animal powerhead starts and stops does not run continuously
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
Ava B.
Nov 24, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
My Dyson v6 animal is pulsating but has been cleaned and been on charge All night
Ava B.
Nov 20, 2016 | Dyson V6 Absolute Bagless Cordless Hand...
Vacuums Logo
693 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Gerry Harvey
Gerry Harvey
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
