Question about Sewing Machines
Tension of needle thread it is creating loops on the underside.
  • Sewing Machines Master
  • 12,731 Answers
No, no, no. Do not adjust the bobbin. It is a top tension problem.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Loops under the fabric frequently indicate the thread is not completely seated in the top tension.
Posted on Mar 26, 2018
  • 2,005 Answers
Adjust your bobbin tension
Posted on Mar 25, 2018
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
Ruth Peck
  • 69 Answers
SOURCE: How do you adjust the bobbin tension on a Singer
With your slide plate open, you will see 2 screws on the bobbin case. You need to adjust the one on the inside (not the one that sits at the edge of the metal strip). Do so very slightly. If you can't seem to get it adjusted, take a look and make sure there isn't any thread or lint in between the two pieces of metal that the thread feeds through. This can cause a loose tension.
Posted on Mar 01, 2009
mohammed387
mohammed marika thambi
  • 1952 Answers
SOURCE: my needle thread keeps bunching and llooping on
If you getting loops on the bottom of your material, you need to re-thread the top of your machine. I say this because it is very rare when you will have to adjust the bobbin tension. But if you must, looking straight down at the bobbin as a clock- at 6:00 is the bobbin tension adjustment- lefty lucy, righty tighty. Hope this helps.
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correct
There is no standard tension for any machine to be set at. They start at four when they are brand new, however, after years and years the springs become compressed. You could start at four and then play around with it from there. If you are getting loops underneath the material, you are threading the machine incorrectly.
Posted on Jul 15, 2009
Anonymous
SOURCE: Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Posted on Nov 27, 2009
SOURCE: I have a Singer 4832 c. I can't find my manual.
check to see if your needle is bent
check your tension
if you need a manual go to diplodocs.com
in the center on the page select brand-
your is there under singer
then product look up model number
manuals are pdf & free
Posted on Aug 05, 2010
Pfaff Creative 2 loops on underside of fabric
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
https://lindeegembroidery.com/common-causes-of-birdnests
Nov 12, 2016 | PfaFF Sewing Machines
Looped threads
Hello Rosemary
Looped thread on the underside are created by the upper thread. Loops on the top of the fabric are created by the bobbin thread. Whichever one is looping, has very little tension. This may be corrected by:
1. Re-threading the upper thread according to manufacturer's specifications.
2. Re-wind bobbin and re-set it into bobbin case and bobbin case area according to manufacturer's specifications.
3. Ensure that the needle is correctly installed and is the correct needle for the sewing machine.
4. Ensure that he bobbin being used is the correct one for the machine.
5. Double check that the tension on the upper thread is at the correct setting.
6. Double check that the tension unit is clean and free of dust, lint or lodged thread/s.
7. Double check that the bobbin tension is correctly set ... if you are comfortable doing so, otherwise leave it for a qualified technician
8. Make sure that he presser foot is down when stitching.
Please let me know how you go.
Happy stitching.
Nov 14, 2014 | Sewing Machines
What is the tension settings for normal over locking with the Elna 4de
First of all ensure that the serger is threaded correctly.
The two setting which you mention are really a 'range' for an 'average' setting.
Using 'average' fabric such as a medium weight cotton, flannel, etc.; set each of the tensions in the middle of the range and test the stitch. There may be minor adjustment required to get a perfect stitch.
Once you have stitched that first sample, here are some possible minor adjustments required:
1. Tear-drop shaped loops on the underside: Check that the thread is firmly set in the tension dial by giving the needle threads a good snug pull above the tension dials while the presser foot is down.
2. The zig-zag like thread on top should meet the ziz-zag like thread on the underside right on the fabric cut edge. If the meeting happens on top: reduce the upper looper tension slightly and increase the lower looper tension slightly ... test sew and recheck. If the meeting is on the underside: increase the upper looper tension slightly and decrease the lower looper tension slightly ... test sew and recheck.
3. If the meeting does happen along the fabric cut edge but the meeting is hanging beyond the fabric cut edge: increase the blade position (that is, move the blade to the right). If the fabric is creating a ridge or tunnel; move the blade to the left slightly.
Please let me know if this has solved your problem. Otherwise let me know what is happening with the stitch quality.
Sep 16, 2014 | Sewing Machines
Why won't my Elna SU model 62c feed fabric through?
Firstly check that you have the top thread going through the tension device and threaded correctly, including the thread take up lever, loops on the underside is a sure sign that the top thread is not under tension. With the broken needles thrown in, it does sound like your machine needs some love from a trained Elna technician. Great machine so worth the cost of a service IMHO.
Jul 29, 2017 | Elna Sewing Machines
My top thread keeps snapping on my consew 118. There are loops on the underside when I stitch with it and the thread keeps snapping at the needle. It is threaded right but it keeps happening literally...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Thread looping on the bottom of your fabric can be caused by little or no top tension or too much bobbin tension. Another cause is thread or lint caught in the top tension.
Make sure the thread is between the tension discs and that no thread or lint is caught
Apr 09, 2013 | Sewing Machines
HD 3000 loops underneath work
It's most likely not the machine. It's the other things, ie needle, thread, etc. combination. For sewing knit, be sure to use a ball point needle. The needle eye size is important to so the thread is neither too small nor too large for the thread weight.
FWIW, it sounds like bird nesting. --the thread is not seated completely in the tension disk. Remove the top thread from the machine and ALWAYS RAISE the presser foot when rethreading!
Also, check that the tension is appropriate for the project. The two threads should meet in the middle of the fabric. If there is top thread showing on the underside of the fabric, the top tension is too loose. Tighten it until it until the top thread pulls the bobbin thread up into the fabric.
All About Needles SCHMETZ Needles
Dec 04, 2017 | Janome Sewing Machines
Needle thread. Is loose underneath
first change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
adjust the top tension one number or letter at a time until the
stitch looks normal
if adjusting the top tension dial doesn't help, you might think about
having the tension dial check to see if it needs to be replaced
Jun 09, 2012 | Husqvarna Sewing Machines
Loopy thread during stitching
if loops appear on underside of fabric, make sure machine is threaded correctly (check instruction manual for threading). when presser foot is resting on feed dogs, needle thread should be quite tight when pulled through needle (needle should bend a little). if thread does not feel tight, check threading again and ensure thread is between tension discs (presser foot should be up for threading and then down to check tension). if threading is good and tension seting is at 5 but still not tight enough check no htread is caught in tension assembly. if tension assembly is clear try tightening needle thread tension to 6,7 or 8 and see if that helps.
if the above is correct check for damage to the needle hole in the needle plate and polish with fine emery tape if necessary.
if you still have trouble best see a technician for possible repair to bobbin case or hook/shuttle mechanism which you may damage trying to fix yourself.
scott.
Jul 23, 2009 | Singer Quantum XL-1000 Computerized Sewing...
There is a small metal 'thingamajig' that the bobbin thread goes by when it sew and every so often the plastic piece goes by that metal thing and cause loops on the underside. why is it doing this?
Be sure that your bobbin thread is correctly placed, is the correct thread for the fabric, usually the same as the top thread, the needle is correct size for fabric. Correct tension - balance your tension, use new needle for each project and correct pressure. Have the machine cleaned-lint build up. Use new thread, sometimes old thread breaks down and creates skip stitches.
Jul 19, 2009 | Elna Heirloom Edition 6005
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
