SOURCE: Admiral Dryer (Model # ADE7005AYW) wire connector burning causing no heat
I had the same problem with my dryer. Fixed it with high temp wire (875 F) and end connectors rated for the same temperature. Make good connections between the wire and the connectors because if they are poor they will heat up as well. Sometimes the thermostat will cause this problem as well or an older heating element that is going bad.
SOURCE: Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
SOURCE: The lint trap on my dryer is moist.
I don't know what's causing the smell, but the moist lint trap and the "takes two cycles" sounds like the exhaust vent is partially blocked.
You can ask the apartment manager to clean it out, or you can take a stab at it yourself with an electrician's fish tape, a plumber's snake, or a dryer-duct cleaning kit. (I picked links from Ace, but you can get them at any hardware or home shop)
Pull the dryer out and detach it from the ductwork. If you're using the fish tape or the drain auger, then you'll want to tie a rag to the end -- washcloth to dishtowel sized at the biggest -- to wipe the lint out of the ductwork. If you've got the duct-cleaning-kit, then use the brush that comes with the kit.
Work your way up and down the ductwork as far in as you can reasonably reach. Chances are good that you'll soon have a huge pile of lint on the floor, and much better airflow through the ductwork.
Hook up the dryer and things should go much better on the next laundry day.
SOURCE: NEED A PICTURE OF THE STARTER SOLENOID CONNECTED
the top two wires dont matter a solenoid is just a switch when you send juice to the solenoid via the small wire it connects the two on the top
SOURCE: changing dryer belt
The drive belt goes around the drum near the rear. It does not use a special groove; it just runs on the surface of the drum. You will need to remove the drum to gain access to the broken belt, motor, and idler/tensioner pulley. It will make more sense when you remove the drum and view the motor pulley and belt tensioner. With a helper, install the new belt around the motor pulley and under the tensioner, then fit it around the drum little by little as you reinstall the drum. Make sure the drum is positioned properly on its rear support wheels, then manually support the front end and rotate the drum slowly by hand. It should rotate freely and the belt should start to track straight as it realigns itself on the drum. If it tracks well, reinstall the front panel, door, top, etc., and check operation.
