Televison & Video Logo
pedzisai mapurazi Posted on Mar 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sansui 53inch tv no backlights - Sansui Televison & Video
Level 3:
Top Expert:
  • Sansui Master 76,851 Answers
  • Posted on Mar 26, 2018
Sansui Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986810
Points
237762
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. https://homenol.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board./
  • Larry Mar 26, 2018
    More generic answers that don't really help .....
    It takes 4 things to make the backlights come on..1st and this is generally the problem, some of the LED's are bad, and will need to be replaced but before cracking the panel open test the other things ...here they are...2nd is the proper voltage to the LED strips in the panel, you can test this with a volt meter to make sure they are what the legend on the board says the voltage should be but if you have shorted or open lamps in the panel then that voltage may start out correct for a second or so then drop to 0 because of over current or voltage, 2nd is you need a BL-On command, you can find that pin on the power supply board by looking at the legend on the board of the pin layout, if you don't have this voltage replace the main board and 4th is you need what is called a PMW (pulse width modulation)signal, its what tells the backlights how bright to be and this voltage needs to be between 1.5 and 5 volts...but if its 0 then the main board is bad as well and with it at 0 the backlights will barely glow, you wouldn't see it unless you pulled the panel apart...That is how you troubleshoot a LED lamp issue...Good luck!!
2answers
My Sansui tv went to a black screen and has no sound
Try these steps to fix the issue with your Sansui TV:
  • Check connections and source
  • Ensure TV is on and power cord plugged in
  • Reset the TV by unplugging it and plugging it back in
  • Verify audio settings and that speakers are on
  • Contact manufacturer for further assistance if needed.
Yesterday my sansui was not showing any picture although it was on,the screen was cold. today the power button does not turn on.
Sansui HDLCD3700 -- Turns On, No Picture/Sound - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
May 20, 2013 - 7 posts - ‎3 authors
Sansui HDLCD3700 -- Turns On, No Picture/Sound ... My Country: USA ... not been able to get any sound or video at all (no backlight either).
Sansui hdlcd185w repair - YouTube
? 2:25
https://www.youtube.com/watch?v=qMpiC8YL3SE
May 31, 2013 - Uploaded by After Hours Tv & Pc repair
Thanks so much for posting, saved my kitchen tv from the landfill!... Also the buttons on the side of the tv do not work correctly. ...Any suggestions? .... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW - Duration: 5:29 ...
Screen lcd problem WESTpoint TEN 3212
I am working on a Westpoint TEN-3212 Led Tv. Found the IC on the panel backlight board burnt. Could you please give me the IC number since I cannot seem to find the backlight driver board on sale anywhere.
Uneven backlight
Your set is probable defective
My sister has a Sansui Flat Screen TV - she says that the backlight is not working. Can this be fixed and if so how? I appreciate all your feedback(s).
A backlight fault can be caused by several things. You could have a defective 24vdc output from the power supply board, defective main board, bad backlight inverter, or a bad bulb inside the panel. With so many possibilities, I would recommend that your sister get a diagnosis. You could also try googling the TV model #, sometimes the problems are redundant with certain model #'s
My Sansui LCD TV scren is black but there is still sound and when u change channels, you hear it changed the channel but no picture! its all black
The backlights inverter board or the power supply section for the backlights inverter board may have gone out, you need to take it apart and troubleshoot it with proper tools.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
I have sound but no picture.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.It a long board in shape.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
2helpful
2answers
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
