Question about Ricoh Office Equipment & Supplies
Ricoh aficio sg3110sfnw - error code "service call (20200)-cannot use the machine - turn power off then on " what must i do it doesnt help to turn power off and then on
    Top Expert:
  • Ricoh Master
  • 55,370 Answers
Make a phone call to your Ricoh servicer and report code 20200.
Posted on Mar 26, 2018
  • Ricoh Master
  • 10,749 Answers
Earlier FIXYA question in 2013 suggested changing the ink collector unit.
http://www.fixya.com/support/t20129290-ricoh_sg_3110dn_sc_20200
Another internet site suggested cleaning the print head 3 times and if not successful, buy a new printer.
https://www.justanswer.com/printers/9mz8y-sg-3110dn-fix-error-20200-unblock-magenta.html
Ricoh SG 3110dn SC 20200
6ya staff
SOURCE:
Anonymous
  • 13 Answers
SOURCE: Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Posted on Apr 29, 2008
Anonymous
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Posted on Oct 19, 2008
Anonymous
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
Anonymous
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Ricoh SG 3110dn, SC 20200
you need change ink collector unit.
Sep 16, 2013 | Ricoh Office Equipment & Supplies
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
I turn on my ricoh aficio 2027 this code SC670 APPEAR
670 D Engine response error After powering on the machine, a response is not received from the engine within 30 seconds. • SBCU installed incorrectly • SBCU defective • Controller board defective
You can try to reseat the connectors on those 2 boards, if that doesnt work you may need to replace those boards.
Mar 15, 2010 | Ricoh Aficio 1035 Copier
Ricoh 3800c call for service
On the screen where it says "Call for service," there should be an error code (starting with "SC" and ending with a 3-digit number). This code can tell you what is wrong with your machine -- what code is displayed?
Does turning the machine off (with the main, orange power switch) and then back on clear the error message?
Feb 11, 2010 | Ricoh Aficio 3800CMF Laser Printer
Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh aficio 2022 error code sc542
2. 107
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
2,013 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
