Chat with Reebok support:
https://www.reebokfitness.info/support-zr8-treadmill
Official Reebok Fitness
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: I am getting an E7 error code on the LED screen. I
hi was wanting to no how much to replace speed sensor on treadmill thanks on,{ model hs1175t hornet 2006}
SOURCE: Our Nautilus T514 treadmill stops
Hi
Try clearing the error by unplugging the treadmil. if it doesn't clear then try and press stop button for 10 seconds. Insure cable is connected securely to Console. All wires in cable should be intact. If any are cut or crimped, replace cable. If error doesn't go then lubricate the treadmill as given in this manual---
Nautilus Treadmill 514 Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
SOURCE: I have a steelflex XT-3600
1. If E6 or E7 appears during power on or during operation, turn off and restart
treadmill. If E6 or E7 still appears on the display, turn off and restart treadmill again.
If this problem persists, go to next step.
2. If the treadmill stops at higher level, press "STOP" & "DOWN" buttons at the same
time for 3-5 seconds to reset the elevation motor to bring the unit down to zero
position. Or else, press "STOP" & "UP" buttons at the same time for 3-5 seconds to
bring the unit up to zero position.
3. Turn off and restart the treadmill, the unit should show at 0% elevation and press
Quick start to begin.
SOURCE: I was using my DK
I was using my DK City treadmill and suddenly it stopped and now sometimes move and after few seconds stops, it shows E1 error.please help us....
