Checking Oil
Check oil level immediately after fill- ing the reservoir. To check oil, bend an ordinary pipe cleaner into a 1/2" long hook and dip it into the oil reser- voir. If oil touches the end of the pipe cleaner, the fan has ample oil. If it does not touch, add SAE 10 non-detergent oil slowly until it touches the pipe cleaner.
Your Original Hunter's unique lubricating system
The bearings are submerged in a bath of oil. The oil moves up a spiral groove in the shaft, lubricating all bearing surfaces as the fan operates. This Lubrication System does not normally "use up" or require the addition of extra oil once the oil reservoir has been filled to the correct level. This unique lubrication system is one reason your Original Hunter Ceiling Fan will last a lifetime. It is highly unlikely that you will ever need to add oil to your Original fan once it is installed. Should you move your fan to another location, it is a good idea to check the oil reservoir. Hunter has developed an accessory 'Original Relocation Kit' that includes all mounting hardware and a fresh tube of oil for this reason. The model number is 22360.
CAUTION: DO NOT TURN FAN ON UNTIL LUBRICATION HAS BEEN ADDED. TO OPERATE THE FAN WITHOUT OIL OR WITH LOW OIL WILL VOID YOUR WARRANTY
Adding oil
Your fan has been shipped without
oil in the motor. A 1-ounce tube of
high grade SAE 10 non-detergent oil
is packaged in the sack parts. All the
oil in the tube must be put into the
fan. Cut the tip off the tube and place the tube into the oil hole. To avoid overflowing during filling, allow oil to gravity flow about one minute to fill the oil reservoir. (It may be necessary to puncture the tube to allow air in.)
SOURCE: need manual for adventure hunter from cabela's
If you hit "+" during the game, it should bring up a menu. You will likely be able to view the controls there.
Otherwise, I would assume that you walk using the joystick on the nunchuk and turn by aiming the wii remote.
SOURCE: Want to return part #
You will have to contact the company you purchased it from. Here at FixYa, we don't sell anything,
I hope this was of some help to you.
