I've got a 6 yr old grandson blind from LCA, that loves to be active. Wondering if you have summer program or camp activities for this age.
Dear Sandra,
We have no summer camp. Actually, we have no camps at all. Sorry.
Fixya is a group of people who try to answer PRODUCT problems with items around your house, inside or outside.
God bless your efforts with your grandson.
P.S. I might suggest you type "Summer camp for blind children" into the search engine of your computer.
SOURCE: Cannot activate bluetooth
Can be a common problem with Samsungs, Have seen it a few times. It is a software glitch. you will need it re-flashed with the phone firmware. Any repairs shop should be able to do this for you.
I could help you, but am probably not local enough to be able to, you will more than likely have a local repair shop
SOURCE: whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: 2 yr old inground pool Hayward pump louder than
If there is air in the pump it cavitates and can make it run louder, otherwise it is the bearings in the motor.
SOURCE: HAVE AN 11 YR OLD HEIL DC 90 FURNACE..AS A 2ND
Go to Heil furnace \ there is a flame rod that sick into flame on burner. Clean with sand paper or steel wool. And retry furnace. Rus
SOURCE: Upgrade info :PowerDVD 6 CD-Key to activate
haardi haarhaaa- we are not pirates here... But you could try and search it from piratebay.com
The recommended stove for summer backpacking is a canister or an integrated stove system.
