This is an uncommon problem. There does not appear to be a scree flip setting in the menu. You could try for a reset of the set but I suspect that would do nothing except require you to retune your channel settings. It is possible that the set was jarred or some vibration occurred that cause a loosening of the ribbon cable to the timing control (TCON) unit in the set. One could try resetting that ribbon cable. Otherwise, the fix might involve replacement of the main board. The video settings menu controls do NOT offer control of the screen flip.
Here is a service manual for a Sansui 32 inch HD.
SANSUI HDLCD3200C Service Manual
That would leave you to tapping Sansui support if this information doesn't suffice.
Support
