SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
SOURCE: craftsman riding mower manual trans.hard to put in
lt 1000 craftsman lawm tractor hard to put into gear running or not
SOURCE: craftsman riding mower stuck in 3rd gear
you have a broken shifting fork in the transaxle, i know this, i just replaced one on a mower that was stuck in third gear...
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
SOURCE: Craftsman LT1000 Wont crank over.
This is not always the case but on Briggs and Stratton it may be time to check the valves for adjusting. Take off the cover and check for a gap of .005 . If the exaust valve is loose it will not allow the engine to relieve combustion to start. In other words the engine stays under load of compression and can't turn. In my shop I see this all the time . If all electrical checks out try this next
