Washing Machines Logo
K
Kevin Blyth Posted on Mar 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool wwdc7410 (sixth Sence) washing machine that is showing a F12 error, can it be fixed easily?
Dw Wooten
Level 2:
Sergeant:
  • Whirlpool Expert 227 Answers
  • Posted on Apr 02, 2018
Dw Wooten
Whirlpool Expert
Level 2:
Sergeant:
Answers
227
Questions
Helped
115643
Points
551
F12 is a problem with the heating element if you not sure on have to check it, u migth want call a appliance tech to fix it ok
5 Related Answers
Anonymous
  • Posted on Jan 01, 2009
SOURCE: Whirlpool Cabrio HE washing machine
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Anonymous
  • 6 Answers
  • Posted on Sep 09, 2009
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Anonymous
  • Posted on Mar 13, 2010
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Anonymous
  • 15935 Answers
  • Posted on Sep 07, 2010
SOURCE: Error code F13 is showing
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Anonymous
  • 1998 Answers
  • Posted on Jan 16, 2011
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Ad
    Error message F08 coming up - can you help ?
    remove the top of the unit and there you will find the paper work that has the codes specific to that washer.
    How to reset whirlpool 6th sense washing machine
    We have just bought a whirlpool zen 6th sence when we tried to do 1st wash without clothing we couldn't get the programme dial to move or wash to start. It just has 6.00 and a washer and 8 on its side symbol
    F- code does not show code in book what and how to remedy the problem?
    Hello there again here is some more info for you
    Whirlpool Washer Troubleshooting: Error/Fault Codes Whirlpool Washer Troubleshooting has been made easier since newer Whirlpool washers generally display a consistent range of error codes (or fault codes) when problems develop so that owners and service personnel can quickly troubleshoot the problem and fix it easily. The Fault codes address a wide range errors that occur with Whirlpool washers, everything from water and power problems to basic maintenance routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
    I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
    We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
    1helpful
    Whirlpool 6 sence error code f h
    Means no water getting to machine or pressure switch not tripped. Check all water valves are switched on and there is water. If the machine is filling up then flashing FH then it is most likely your pressure switch that is faulty. If there is no water at all then its most likely you water inlet valve. Both of these are easily changed by removing the top panel. The pressure switch is a round part about 2-3 inches and has a thin tube pushed onto it and a wiring plug. The valve is at the top back, most likely if there is 2 hoses then it will be the hot water 1. Hope this helps
    3helpful
    Hotpoint aquarius wd440 showing f12 error code how can i fix it
    F12 - Communication error a thing to try is resetting the machine to do this turn machine off at plug for 5 mins then back on and start a cycle and see if it happens again. hope this helps.
    2helpful
    Machine wont work and flashes f12 on function display
    F12 is classed as a communiction error.
    Either faulty connections or electronic panel
    53helpful
    3answers
    F12 Error
    what is F12 error code on a siemans wxlp1400 and how do i cure the fault, cheers
    Washing machine prob
    You need to replace the door interlock. Try giving the handle a firm push and see if the machine will start.
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
