SOURCE: connecting Creative Gigaworks S750 computer speakers to panasonic plasma tv
This depends on the audio system setup designed on your television.
Most speakers can have adapters bought for them which will allow you to connect your speakers to a television. But not every TV will support the 7 speaker configuration with PC Speakers.
The good news is the adapters are fairly cheap at Radio Shack and should not set you back more then 10 bucks. Maybe even cheaper.
SOURCE: Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
SOURCE: samsung cell phone speaker o ear hole don't work
the problem with the phone is that the earpiece of the phone i bad, that is why both the speaker and the ear hole is not working.
All you need to do is to change the earpiece of your phone and you will see that you can now hear what people say on the phone.
Change the earpiece as said, with the earpiece changed, you will be able to hear when making calls.
Take care
SOURCE: speaker phone
i have one ce0168. the problem is that from circut the point of speaker is removed. so the question is that can we get jumper from handsfree point
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
