Hello beth ( a 12 year old monitor , no PC stated or OS)
we need to know first what PC this is.
it has name (HP) and model, like DV7-1234us
my guess is a DESKtop made from 1984 to now. endless types.
the V17 , does have speakers, (if opted day 1)
this means it has speaker cable, all by its self.
that must be plugged in.
The VP17 does not make sound it only makes it louder and sends it to the speakers,inside the VP17.
The PC makes all sounds, never the monitor,
The PC changes volume and so does the VP17 , independantly.
that means if the PC sounds is at 0, zero, the VP17 tries to make
0 sound louder, and fails, 0 times anything is still zero.
im guess.
Turn up the sound in the PC, using windows, controls
then connect the monitor to the PC green jack sound;
using the correct cable.
then turn up the sound on the VP17
and bingo sound.
use the built in sounds in windows to test sounds
control panel, click sound, icon the tab sounds and test button.
NO OS stated is this Windows XP?
no photos present of red/white icon, so?
my guess is you have sound turned off in the PC, so click
the speaker ICON in the task bar, bingo sound?
HP vp17 monitor pushed sound button on bottom of monitor no sound. pushed again nothing. have a red and a white sound icon on screen. how do I get my sound back.
Check out the options on HP support
https://support.hp.com/th-en/document/c01289551#AbT1
SOURCE: White screen on Motorola RAZR
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything!
SOURCE: Philips 170S4 white screen not display.
its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
SOURCE: Blue buttons (quickplay/sound/dvd controls) won't work
Mine did that as well then after rebooting started working??
SOURCE: hp 1730 monitor will not turn on
There are multiple circuits for this model. I suspect your model is
PE1237. If so this model frequently has bad solder connections at the
AC socket. Also capacitor 2119 or capacitors 2041 & 2031 can cause
no power up. They normally are bulging if bad.
If your model is PE1238 (BenQ), you may see bulging capacitors in the power supply.(1000uf/25v)
Monitor Mike
SOURCE: sound button is red on strip of hp pavilion dv
chk the volume control if thats ok try using a head phone which is working if it works then problem with speaker
