Sounds like a screw or similar spinning on the spin cycle but can't get the screw out of my fuzzy logic 6.5kg WF-T652 washing machine. Don't want to force it... left or right. ??
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
may sound crazy, but sometimes the water pump gets clogged and does not operate, so will not spin. safety feature, I guess.
Try cleaning out pump.
Bruno
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
