The camera works fine, but there are fine horizontal or vertical lines thru pictures depending on the camera orientation when taking pictures. In the Review Mode after taking the picture I see "bars" thru the picture then fine lines when looking at the downloaded picture. I put in a new battery with no change in results.
SOURCE: Kodak EasyShare P850 - Black screen
I have fixed several Kodak models including this one with exactly the same problem. Sometimes tapping on the side will fix it temporally. The fix is to open the back of the camera and snap the connector from the lens. If the camer is dropped the connector can come unsnapped. You should only attempt this if you have had some experence working on electronics. Be careful inside the camera especially in the upper right corner which is where the high voltage is for the flash. You can get a large shock from this camera if your not careful.
SOURCE: Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Cannot 'review' pictures on the Kodak EasyShare DX6490
press the EVF/LCD button in top left corner of camera
SOURCE: Horizontal lines running through pictures.....Z612.
I've had sinilar problems with mine. I bought it in November of 2006 and sent it back to Kodak (under warranty) 3x before they finally agreed to replace it (with a refurbed unit). Well, that was in June of 2007 and the problem is now baaaack with the reoplacement camera (same model)... I'm requesting Kodak replace it with another model, but I'm "out of warranty" and they want me to pay them $145 to repair (which they've never been able to fix for me). So I am requesting them to replace with a different model.
SOURCE: Kodak EasyShare Z612 Shuts down after taking a few pictures.
Question :
What batteries can I use in my digital camera, and how long do they last?
Battery life depends on how you use your camera, the type of batteries you select, and how you handle the batteries.
Your camera is compatible with: KODAK Li-Ion Rechargeable Battery KLIC-8000 and KODAK CRV3 Lithium Batteries: A non-rechargeable battery. (so your battery might be in need of a change)
Using Your Camera
Some features, such as reviewing pictures and using the flash, require more power than others. Follow these guidelines to get the best use of your batteries:
Handling Your Batteries
