Question about Juki Sewing Machines
How do I thread a Juki serger mo-804. Five threads on machine. I need to know how to thread needle number 5
    Novelist:
    Scholar:
  • Juki Expert
  • 90 Answers
Are you sure it's a 5 thread?
I looked at the threading diagram on the 804 and it appeared to be a 4 thread. It looked like an overlock with a safety stitch in the center.
The 5 thread looked like the number was an 814
Posted on Dec 26, 2018
6ya staff
SOURCE:
Anonymous
  • 47 Answers
SOURCE: Need a "How to Guide"
Visit us at www.ifixmachine.com
Posted on Jul 24, 2009
Anonymous
SOURCE: juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
paj42
  • 1116 Answers
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Posted on Feb 19, 2010
paj42
  • 1116 Answers
SOURCE: don't know how to thread the juki mo-735 serger
This video starts off a little ****, but expected if you have ever visited the Threadbanger site - http://www.metacafe.com/watch/1462325/how_to_use_a_serger_indie_pendent_designer_spotlight_thread_he/ Not your brand, but the same "serger basics". Lift the antenna to it's highest position. Set the tensions to zero. Have the presser foot up when threading. Raise the upper looper to it's highest position. Sergers are great little machines, but they can be nerve racking when it comes to threading. After years of threatening my old FunLock, I bought a Babylock Imagine with air-jet threading - what a relief!
Posted on Mar 12, 2010
Testimonial: "Thank you very much. i like the website that you suggested!!"
flowersinpar
SOURCE: JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Posted on Nov 18, 2010
I am having trouble threading the needles of my Juki MO-2516M serger
Be sure you are using a needle size suitable for the thread weight you are using.
Try this method for threading needles:
Lick your index finger and swipe it across the back of the needle eye.
Aim the thread cut end above the needle eye and slide it down to the eye. It should go right through the eye.
Jun 06, 2018 | Juki Sewing Machines
How to thread a Juki MO 816 DD6 industrial serger, please.
Did you get a book with it? If not, buy or access one online.
Copy the threading diagram from the book:.
1. Blow diagram up to full page size on the copy machine.
2.Make as many copies as the # of threads you are going to use (3 threads=3 copies, 5 threads=5 copies etc.)
3.Buy as many colors of magic marker as the number of threads you are using. (Or borrow from your kids, the neighbors or use crayons)
4.On copy #1, using the original threading diagram, use one color of magic marker to follow the thread through its patch from the thread cone to the needle.
5.Do the same with each of the other copies: Copy #2=thread #2, Copy #3=thread #3, etc.
6.Now you should have a page for each thread as it comes off the cone.
7.Use a thread color that corresponds to the magic marker color on your page to make it clearer. After it is threaded properly, you can tie the color you plan to use and pull them through.
By using different color threads, and a good light, it is easier to see if you have missed a place or crossed a couple thread improperly.
If all else fails, try to find someone else who knows how to do it to thread it for you, then take a couple close up pictures of the inside of the machine with it threaded properly, take them to the photo shop and have a copy made to keep with your machine to refer to in the future. Good Luck! Sergers are their own nightmare to thread but once you get it down, you will be fine and love it. Juki is one of the easiest of the bunch. If you have a pair of tweezers and a couple threading wires, it sometimes helps!
Jun 25, 2016 | Juki Sewing Machines
Juki Serger - MO-50e thread will not move out of the machine and continues to tangle under the needles. Please help! The machine worked beautifully for a few hours and now it is a really expensive p
I have had this happen, check your tension on that thread and check the thread thickness. Tofix mine I recall changing both,and I think it was the thread thickness in relation to the tension
Oct 29, 2014 | Juki America, Inc Juki MO-50E 3/4 Thread...
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
JUKI MO 134 SERGER
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Don't know how to thread the juki mo-735 serger
Mar 12, 2010 | Juki MO-735 Mechanical Sewing Machine
Good diagram showing how to thread a 4 thread Juki 644d serger we do not have a manual machine is not clear
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Mar 02, 2010 | Juki MO-644D Mechanical Sewing Machine
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
70 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
