How do I correct this?
OOOOKKKKK!!!
GO to GOOGLE and search for these EXACT words:
BUT search under "IMAGES" at GOOGLE
Lexus GS300 model 2006 map dvd
Lexus GS300 model 2006 map dvd Google Search
Now go to EBAY and search for:
"Lexus 2006 GS300 map dvd"
91results for Lexus 2006 GS300 map dvd
Find them starting at $10.99
(and free shipping)!
Anthony
SOURCE: can't get the DVD player to wok in my 2006 Lexus GS300
Repair Procedure
1.
Confirm the customer's complaint of DVD RSE system inoperative.
2.
For vehicles with Lexus Navigation System, perform the following procedure to turn OFF the RSE Lock function:
A.
Press the INFO button to display the "Information" screen on the navigation unit.
B.
Press the "Screen Setting" touch button on the navigation display.
C.
Under the "Rear Lock" option, press the "OFF" touch button and then press "OK" in the upper right part of the display.
D.
Press the DVD switch on the RSE system, (If a DVD is NOT already in the player, insert one) and confirm screen is "ON" and the system will play DVD's.
3.
For vehicles without Lexus Navigation System, perform the procedure to turn "OFF" the RSE Lock function.
A.
Push the audio control knob multiple times to cycle through the various options (Bass, Mid, Treble, etc.) until "Rear Lock" is shown on the screen.
B.
Turn the audio control knob so the display says "OFF" next to "REAR LOCK".
C.
Press the DVD switch on the RSE (if a DVD is NOT already in the player, insert one.) and confirm screen is "ON" and the system will play DVDs.
4.
If the above procedure resolves the concern, explain the system operation to the customer. This procedure is described in the "Audio/Video" section of the vehicle owner's manual.let me know lf this helps.
SOURCE: changed battery in 94 lexus GS300, now the check
try to take cables off battery let sit for five or tem min. then put + on first
SOURCE: how to change spark plug on lexuse gs300 2003
You need a new Spark Plugs Spark Plug Wrench Socket wrench Extension (At least 2-3 inch) size 10 socket size 12 socket...
First thing you need to do is find out where the spark plug cover is. Once you figure that out there will probably be size 10 or/and 12 bolts honding it down. Take that off and there you will see sensors connecting to each other and holding the spark plug in the cylinders. Unplug all the sensors and pull out the circular plugs holding the spark plugs down. THey might be a little tight and hard to get out so you're going to need to give it a good tug. Once you pull them out MAKE SURE YOU DONT DROP ANYTHING INTO THE CYLINDERS. You can look down into them and see the spark plugs. Get your spark plug wrench, extension, and socket wrench and stick them down in and push so that the spark plug wrench grabs them. Just simply unscrew the plugs, pull them all out, and then put the next ones in, and tighten them down. Just connect all the sensors, and put the cover back on and you're done. Pretty simple.
Take care
