Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag washer - loud rattle metal-sounding noise while spinning
I called our service tech to look at my Maytag washer in May because the wAsher was vibrating and moving around the floor while spinning and was it was noisey during the spin cycle. he lubricated snubbers and leveled legs. noise and movement seem to settle until recently the noise was back (machine not moving around, but still noisey) and yesterday he tells me the brake bearings that sit on the transmission need replacing and i should replace the snubber assembly while doing the brake repair/replacement. the total pice...$420.00!!!! In my reading on the website, fixya., the fellow says, and i quote
"You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is located to get rid of some noise related problems (this will be the round metal plate where the tub support meets the bottom casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking of the washer when the spin cycle stops. If the corn starch tip does not get rid of the squeaks, I would recommend replacing the following parts: Brake Stator
Brake Rotor and Lining
Snubber:
SOwhat do you think? Do you agree he should not have lubricated the snubbers. At this price, i would be a fool to do the repair. I should just purchase a new machine. Sadly, for me, this machine is only eight years old and the reason I spent the $$$on Maytag was for longevity. What a huge disappointment unless, of c ourse, this fellow misdiagnosed the problem. Your thoughts are appreciated. Thank you.
3 Suggested Answers
6ya staff
SOURCE:
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: I'm looking for a video to replace a snubber in my
I'm assuming that since you mentioned a "snubber" that the washer you are referring is a Maytag manufactured top loader (Admiral is manufactured by Maytag). If so, the following link can give you some guidance on how to repolace the snubber and/or brake assembly:
https://www.fixya.com/support/r3574320-maytag_washer_squeaking_problem
I have included part numbers for tools you may need and some advice on what you can do to avoid having to purchase any higher priced special tools.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Recommendations on parts that may require replacement:
Brake Rotor with Lining
Brake Stator Snubber
The part numbers will be based on your MODEL NUMBER.
Prices will vary between the sites I have listed, so shop and compare. The first three sites I have listed, have helpful exploded view diagrams to assist you with locating and properly identfying the parts you need. If you search by model number, these parts are listed under the "Transmission" parts list. This is not a difficult repair, and the parts (including most of the tools) are not expensive.
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Posted on Feb 03, 2011
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: if my washer makes a squealing sound during the
one of the above. Tip the washer back and turn the main drive pulley while spraying a little WD-40 in there. That will quiet down the washer.
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 22, 2011
My maytag performa pav 2300 is making a loud noise while its spinning. Sounds like metal on metal. Its working fine. Its just that noise. We just got a new motor yesterday. What could be the problem ?...
Hello
On this model washer the noise is most likely caused by a worn washer tub seal assembly. remove agitator (nut on the top under cap), spin basket and tub assembly. remove seal and install new one.
Nov 03, 2011 | Maytag Performa PAV2200
My washer makes a very loud noise at the end of
the knocking noise im used to on the maytag is typicall coming from the idler pulley. i almost sounds metal on metal and is related to the transmission. if this is the case the problem is major and my cause a tear down just to find the problem. most techs will mark this out as scrap. i hope this isnt the case for you
Aug 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Epic Z Washer has object between drum and tub.
I had the same rattling during spin cycle of my Maytag 4000 series front loading washer. Noticed you could gently pull back on the rubber gasket between the tub and where the door seals. There was a quarter resting against the fixed ring the tub spins in. Problem solved. And I have further realized that long hair can build up in this same spot. But if you didn't know to pull back on the gasket you wouldn't see it. Good luck!
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Spin cycle is very loud but works well
my neptune was so loud it sounded like it was taking off, it turned out to be the bearing in the drum, the repair man wanted $1200. to fix it. i called maytag and this part has a lifetime warranty and they sent it to me in 2 days.
Feb 11, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
New washer, Maytag title, but RCA unit--knocks and clanks
Thank you for your complaint. It will be forwarded.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Neptune MAH5500AWW make noise like metal rattling
may have something in the pump or one of the struts off
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
430 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
