It's a white (older model) white, one front door.
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
SOURCE: Kenmore Upright freezer needs cleaning under bottom shelf
most of the sears freezers . lift up on the shelf that will unlock it then slide it left or right ( it may move a little hard ) that will unlock the other side , lift and remove ( one side at a time ) ... you will see its not that hard , its just hard to put it in words .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
SOURCE: Freezer does do not have a tight seal at the bottom
it's an easy question! ans: support your leg in the bottom part of the door and pull the top part of the door with your hand with a great force.......it will seems to be bendind. dont worry. it will just make the door parallel................have a nice day :-)
SOURCE: I have an upright freezer and replaced the rubber
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
SOURCE: Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
