SOURCE: Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5)
Non-CPU: Can be used in mode M, but exposure meter does not function;
electronic range finder can be used if maximum aperture is f/5.6 or
faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
SOURCE: Have a Nikon D60 and after I take a photo, I get
You need to press the Disp/Display button to remove the settings on the display.
Testimonial: "Also had to use the multi selector to get rid of it. I now understand the process. Thanks"
SOURCE: Date/time needs to be set every time camera is
In most cases this is an indication of some sort of water/liquid damage on the board.
Or a "memory cap". on the board needs to be replaced
