Also tried another site listed in one of the answers but that didnt work either
A 2003 model will be unlikely to be available except on eBay or in a second hand charity shop.
Can you tell if this eBay vintage (meaning old...) model is the same one or not? Eventually, if you check eBay you find one with a manual.
https://www.ebay.com/itm/Vintage-GPX-Karaoke-Machine-Dual-Tape-Deck-with-Microphone/152831786844?hash=item23957bff5c:g:mZoAAOSwk1haNniq
Vintage GPX Karaoke Machine Dual Tape Deck with Microphone eBay
SOURCE: AUX connection from Tape Karaoke Machine to CD Player= no music
Probable that it IS Outdated. CD input May be to Hi or Low for "OLDER" Units
SOURCE: GPX Karaoke Machine with AM/FM radio and cassette,
On the rear of the unit, the RCA jack on the lower left corner of the jack panel should be yellow and marked Video out. take a RCA to RCA plug into the video out on the unit, then plug the other end into Video in on the TV.
I'll attempt to send you the manual thru the link below:
http://www.gpx.com/owners_manuals/JM250S-IB.pdf
Good Luck, and don't forget to rate the answer. Let me know if this doesn't help.
M
SOURCE: gpx c1600 karaoke machine not powering on
I would check the power supply area inside of the unit to see if there is anything suspicious looking.
