Question about Philips Televison & Video
I have a Philips TV model 50FPF5332D/37. There is no picture and no sound.
The power supply board has an troubleshooting led light. The LED is on steadly indicating no power supply errors. The controller board has LED 2002 flashing continually. What does the continuous LED 2002 indicate.
    Top Expert:
  • Philips Master
  • 76,171 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location./
Posted on Apr 06, 2018
6ya staff
SOURCE:
Paul
  • 224 Answers
SOURCE: Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Posted on Oct 03, 2008
AMJAD HUSSAIN
  • 586 Answers
SOURCE: Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Posted on Nov 19, 2008
Anonymous
  • 106 Answers
SOURCE: Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Posted on Jan 05, 2009
Chi Chu
  • 8457 Answers
SOURCE: My Green power LED is flashing continuously.. no
Ur power supply board is dead,need a new one.
Posted on Sep 30, 2009
Anonymous
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Posted on Dec 14, 2009
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
Phillips 37PFL5332D/37 I have a blue power light but no picture, sound or anything. Please advise?
When tv power on.U have a solid LED green or red power light incadication?Yes,than 100% ur tv Tuner signal board is the problems and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 13, 2011 | Philips 37PFL5332D 37 in. LCD Television
Phillips ambilight TV Flashing red LED light--- ^ long blinks and then 3 short blinks--- picture and sound will not come on---
Check the tv power supply board for those dying parts call copactors.That the board,where the power a/c cord plug into it.These capacitors are alway bulges or puffing up on it tops.U have tools and know basic electronic?Replaced those dying soon to be dead capacitors,will fix the power supply and have stable tv power again and tv will work.Or try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 23, 2010 | Philips 50PF9731D/37 50 in. Plasma...
My Philips TV 37PFL5332D/37 has the inverter problem with power and sound but no picture (black screen). I am ready to purchase new inverter(s) but I am confused which one. I thought this model had 2...
http://electro-medical.blogspot.com/
Apr 02, 2017 | Philips 37PFL5332D 37 in. LCD Television
Turn itself off as soon as you turn it on (37MF33ID/37)
in the lcd tv there are three main parts
1)the inverter board(pannel)
2)the main board .
3)the power supply board.
if there is no power at all them main board is faulty.if no front led light is coming ON there is no power .so the main board is faulty.on the main board there is a fuse located you have to replace that and check first if still no power main board needs to be checked and replaced
if there is sound but no picture and front led light is ON then its inverter board panel problem.if this is your case replace inverter panel.its located in the lower side of the lcd in the inner area below the main board.
but if there is just front led light blinking , but no picture or sound then its power supply board problem.
but as you mentioned that the tv turns ON for some seconds then automatically turns off this indicates that the power supply board is not faulty but there is a component on the board that is getting over heated because its got weak so due this overheating of a component the circuit gets short and tv shuts off.
on power supply board there are some capacitors and ic located.if any of the component gets short or budged up then it short the power supply board.so you can check the components on power supply board with multimeter and get it replaced by using soldering iron.
also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Feb 20, 2010 | Philips 37MF321D 37 in. LCD Television
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
42 plasma tv model42mf230a/37 blue light on no picture no sound
with solid blue led set could be still powering on but would need to verify by checking power supply voltages. if up and signal is present with no menu or audio would be ssb as audio amplifier, micro processor and eeprom are on that board. if voltages are not present you need to offload x and y sustain boards one at a time from power supply and check voltages and if vs comes up with either board disconnected replace that board
Jul 25, 2008 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
