Televison & Video Logo
Logan Cormany Posted on Apr 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dark picture on samsung led tv
Hi I have an older samsung led tv. I am having trouble with the screen being dark. I have replaced the t-con and power supply board but there are still areas on the screen that are darker than others. Before this the screen was completely dark and the only way to see the picture was with a flashlight. Could the LED strips be going bad as well? The model is UN46H5203AFXZA
City View TV & Computer, Inc.
Level 3:
Master:
  • Samsung Master 453 Answers
  • Posted on Apr 14, 2018
Samsung Master
Level 3:
Master:
Answers
453
Questions
Helped
147771
Points
1036
Please replace all of the LED back lights strips.
5 Related Answers
gopakumarg43
  • 76851 Answers
  • Posted on Feb 16, 2015
SOURCE: screen on tv went dark everthing works but screen is darker led seiki 322fs
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
claudeinmo
Claude Kayser
  • 9098 Answers
  • Posted on Oct 16, 2015
SOURCE: How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
enquiries83820
George
  • 132 Answers
  • Posted on Jan 13, 2016
SOURCE: On my Hisense 50K23DG LED TV, I have sound but no picture.
Hisense TV's usually use PCB Boards by Vestel and not Hisense themselves, have a look at: Vestel Help If the Boards in your Hisense match this Board/Part Number format at least you'll know what to search for, replacing the power supply will not help unless the process has been incorporated into the power supply and that is not known for certain yet
Good Hunting
claudeinmo
Claude Kayser
  • 9098 Answers
  • Posted on Jan 27, 2016
SOURCE: Samsung LCD... Power supply, t-con or inverter?
Samsung LCD TV Repair - TV Won't Turn On - How to ...
? 8:22
https://www.youtube.com/watch?v=n54IurMvr6o
Apr 4, 2014 - Uploaded by ShopJimmy.com
So in this video today we are going to be looking at a Samsung LCD and how to diagnose if you have a bad main or a bad power supply.
Samsung LCD TV Fixing Power Supply Problem - YouTube
? 10:52
https://www.youtube.com/watch?v=F6qgCg8lsxc
Dec 23, 2011 - Uploaded by Studio G Vision
Samsung LCD TV Fixing Power Supply Problem. Studio G Vision .... How switch mode power supplies (SMPS) work - Duration: 19:22.
Samsung LCD TV Power Supply Repair, Capacitor Replace ...
? 25:23
https://www.youtube.com/watch?v=lL0id3-YZsQ
Feb 9, 2013 - Uploaded by HandySavesMoney
... LN46A630 LCD TV. This procedure will apply to several otherSamsung TVs. ... Samsung LCD TV Power Supply Repair, Capacitor Replace, LN46A630. HandySavesMoney .... Country: Worldwide; Restricted Mode: Off.
richie46
  • 12962 Answers
  • Posted on Aug 12, 2016
SOURCE: Hi. I have a Samsung LED 46" model #UN46EH5000FXZA, with no picture but has sound.I replaced the power supply board & T-Con board & still no picture but have sound. What can I do next??
Do flashlight test to see if y0ou can see an image - if so replace the inverter board that powers backlights. If no image then go for the main board.
2answers
Can bad T-Con board cause Samsung TV to flicker off and on?
I think an LED problem is more likely. The LED strips are usually powered by a driver circuit on the power supply board. You can check this with a bright flashlight shining on the front of the display at about a 20° angle from parallel to the display. If you can see the picture or the menu with the flashlight beam during the "dark" period, the problem is NOT likely to be the T-Con board.
You can also look at the back of the set with the cover removed - most sets have a number of vent holes in the back plate through which the backlight can be seen when it is on. If these holes go dark when the TV goes black, the backlight is being turned off.
When the screen is lit, take a picture quickly and look for dark spots. Maybe one of the LEDs has a partial short that shuts down the LED power and triggers a retry cycle. If so, after a while it will burn out and then the entire LED strip will be inoperative.
Bad picture on my old Samsung TV - is it the t-con board?
@sam8823 “Now is it possible to damage T con board this way “ absolutely possible. Unlikely that you damaged the panel (sure always possible, but unlikely). “This “Also there were two conductive tapes between Lcd panels (one on left and one on right panel) and TV body. “ sounds odd. Post some good images of your Panel and the cables that enter the panel. Adding images to an existing question that way we can see what you see. You need to have more TABS on a 55” TV than 2. Also, let us know what the exact model is.
This is similar to what you are looking for
Samsung UN65J620DAFXZA LED tv - the screen goes very dark shortly after turning on.
It is possible the harmonic balancer/dampener on the engine has given up the ghost. Worst case would be the transmission torque converter is acting up.
https://youtu.be/vM-bz_oBuus
1helpful
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Samsung LED TV problems
try first with the led strips noo need replacing t-con
How do I fix a Samsung UN32EH5300FXZA LED TV with a blank screen, but with backlights and sound working?
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
I have a 75" Samsung LED TV, and the top position of the screen is going dark, is that a power supply issue?
Samsung TV half the screen goes black or dark - YouTube
? 0:38
www.youtube.com/watch?v=Mmu5wq6LVgM
Jan 28, 2012 - Uploaded by DaReal2Face
Samsung TV half the screen goes black or dark. ... My samsung 40" - 14 months old does this on the top half of the screen. .. ****** 12 month ...
4helpful
I have a Samsung 46 " LCD that is 2.5 years old. We had 3 capacitors replaced about 2 months ago, tv clicked but wouldn't come on.Now we have a new problem. The picture will be dark for awhile and then it...
No,this problems it the T-CON decoders board problems.This board sit right in the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
