SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
SOURCE: WASHING MACHINE BLOCKAGE
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
SOURCE: HOW TO REMOVE FILTER ON FRONT OF MACHINE
Turn it anti-clockwise to remove and clean, and yes there will probably be some water run out, so have a cloth/s ready to mop up water.
If the filter handle has a screw in it, undo the screw before trying to move it.
Please rate my solution.
Thankyou.
Testimonial: "after trying to get some answers this was just brilliant there was a screw and the little filter cap came of with a slight turn thank you very much "
SOURCE: I have a hoover washing
e o2 is a not filling with water error have u checked the lines going into the machine as well as the water valve? please remember to rank how this post helped and write back for futher questions thanks again
rickead1
p.s. u can also goto this site and it will help you diagnos your machine http://service.hoover.co.uk/fault-finder/FaultFinder.aspx?Section=11
have a great day
