Computers & Internet Logo
Felix Emeka Posted on Apr 08, 2018
How do i fix my lg 32inch led tv not coming on
The screen is dark , no light on the screen.
5 Related Answers
Anonymous
  • 4889 Answers
  • Posted on Apr 08, 2011
SOURCE: Hi. I got an LED "LG LE5500"
You wil need to connect using a DVI to HDMI cable. You can get one for about 5$
http://www.amazon.com/DVI-HDMI-Cable-6ft-Male-Male/dp/B0002CZHN6
Just connect it and choose the HDMI input its plugged into(1/2/3). If there is nothing on the screen adjust the display resolution on your computer. If you are using 1080i then the resolution should 1920x1080
Testimonial: "YOU ARE AWESOME THANK YOU VERY MUCH"
Anonymous
  • 14553 Answers
  • Posted on Apr 30, 2012
SOURCE: My TV fell and the screen is cracked. The light comes on but no pictures
SORRY, if the panel (it is called a display panel) is damaged this is the end of this set- fatal from a cost point of view as the part if available will cost more than the set did when brand new.
The display panel in all these sets is fragile as you have discovered--even a minor hit can destroy the panel.
SD TECH
vinceisaac
francoise cleofas
  • 2432 Answers
  • Posted on Oct 08, 2012
SOURCE: where are audio out jacks on my LG 32inch flat screen model Ls3400
their is no output jack in this model.
stbccy
Eric Chen
  • 25 Answers
  • Posted on Jan 07, 2015
SOURCE: Can I connect a SamsungSmartTV model VE32H5500 32inch LED to a belkin modemF5D8636 4v2?
You should be able to connect the tv and the router. You may need to avoid to use special characters for wifi password.
Penzance Computers
  • 2003 Answers
  • Posted on Feb 11, 2015
SOURCE: Hi my Hisense 32inch led comes on but no picture please help when I press the buttons on the tv and remote the light blinks on the tv the back light of the tv is on bit no picture
Can you see the setup menu?
How to fix an lg 47LE5400 tv power lights come on but no picture
If it's a led tv and if you have sound and, also, if you can see the picture with a flashlight very near on the screen in the dark, that means your backlight or your inverter circuit that control the backlight are defect. Good luck,
Serge.
2answers
I have no light on my led tv
The most likely problem is the Backlight Inverter. It supplies the power to the LED array which illuminates the screen. If you are brave and also technically able, it can be replaced at home. Here is a video to help. LCD TV Repair Tutorial How to Replace the Backlight Inverter Board in LG...
LG 47LN5750 TV has no back light issue-
replace screen it's faulty period ensure it comes with T-con
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
2answers
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
