Cell Phones Logo
William Ingram Posted on Apr 08, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Galaxy Note 3 that works great but the wi-fi and Bluetooth stopped working. While trying to troubleshoot this it stated that the phone needed to be rooted.
I took the phone to the Samsung store and the tech tested it and said there was no hardware failure. I took it to the repair shop (before finding the root issue) and they were vague about possible repairs. I downloaded Keis but apparently not tech savvy enough. I don't know what can cause a root failure but can this cause the problems I am having and can it be fixed?
270rexton
Level 3:
President:
  • Samsung Master 782 Answers
  • Posted on Apr 16, 2018
270rexton
Samsung Master
Level 3:
President:
Answers
782
Questions
Helped
308228
Points
2472
If the app asking you to root the phone its not official. Rooting is not easy and if you dont know how to do it don't bother as can seriously damage your phone. I would try hard reset or use Samsung Switch (or KIES) and within the menu Phone recovery.
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Nov 30, 2008
SOURCE: nokia n95 keypad light is not working...
hello..
the problem is the water damage mate... cut your loses and get a new one.. spending any money on this will be a waste..
vcmichael
V C MICHAEL
  • 115 Answers
  • Posted on Dec 17, 2008
SOURCE: My Computer is an Acer Aspire M1610 - Won't Start up
Reinstalling windows is the best option.
Anonymous
  • Posted on Apr 07, 2009
SOURCE: hp CUE Status Root has stopped working ERROR
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Anonymous
  • 162 Answers
  • Posted on Jun 02, 2010
SOURCE: Lenovo y430 isn't starting up. took to a repair
Hi, If your issue is your computer wont turn on or wont display anything, you could try power draining by removing the battery and unpluging the ac adapter and press and hold the power button for 15 sec while the battery and ac is out then plug it all back then turn on your computer. If your problem is with the Operating system like XP, Vista or Win 7, you can restore your system to its original factory settings but just a warning it would delete eveything on your computer so you might consider backing up all you important files. Here's the procedure, first make sure that the ac adapter is plugin so that it would not interupt the process if the the battery runs out, then look for a small button just beside the power button that a arching logo on it or the word "NOVO" then press once that small button without turning your computer on because it will just turn on when you press that small button, then it would go directly to the One Key Recovery Option then choose one key recovery on the options given then it will guide you to the whole process of restoring your system to its original factory settings. Hope it helps
Anonymous
  • 2185 Answers
  • Posted on Oct 13, 2010
SOURCE: My Samsung Galaxy 3 -
To be able to find out the MAC address of your Samsung Galaxy phone, please do the steps below:
1. Press the Menu button, under the display on the left hand side.
2. A menu panel appears onscreen. Press Settings.
3. The phone's Settings menu appears. Press Wireless Controls.
4. From the Wi-Fi Controls Menu, press Wi-Fi Settings.
5. Press the Menu button (to the left under the display).
6. A menu pops up onscreen. Press Advanced.
7. The 12-character MAC address is listed in this menu.
There you go, you just have to add the MAC address where required in the appropriate place in the Wi-Fi router's configuration set up.
Please let me know if this helps you. Thank you for using FixYa.
Why will my wifi not stay turned on?
wifi not stay turned on Carol, maybe your cell is automatically switching between Wi-Fi and the mobile internet.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://recomhub.com/blog/galaxy-s6-not-staying-connected-to-wifi
About Wi Fi Assist
http://recomhub.com/blog/lg-g4-not-staying-connected-to-wifi
How To Fix Samsung Galaxy Note 3 Wi Fi Mobile Data Connectivity Issues
Mar 23, 2016 • Cell Phones
Galaxy S6 wifi issue
First, try restarting the Galaxy S6. To do that, hold the power button on the right side of the phone until prompted. Hold it down again to turn the Galaxy S6 back on. It's a simple process but it has been known to dislodge Wi-Fi issues
If that doesn't work, Galaxy S6 users will want to try rebooting the local router if that hasn't been done in awhile. We recommend unplugging the router for a good 30 seconds and then plugging it back in. Users can do the same for the modem as well. Galaxy S6 users might also consider updating the routers firmware. This process will be different depending on make and model. If those simple fixes don't work, it's time to head into the Galaxy S6's settings.
If the Galaxy S6 isn't getting a solid connection, it's time to force the device to forget the Wi-Fi network in question. To do that, head to the desired connection in Settings. On the Galaxy S6, this can be found in the Connections portion of Settings. Once there, select Wi-Fi. Tap on the desired network and select the Forgetoption. Users will then need to reconnect to the Wi-Fi network. Make sure the password is readily available or the device will be locked out.
If that doesn't work, head into Wi-Fi, tap More in the top right corner, and select Advanced. Ensure thatAlways allow scanning is turned on. You'll also want to make sure that Keep Wi-Fi on during sleep is set toAlways.
How do I connect my Samsung Galaxy to BT broadband?
Are you trying to connect via wi-fi or via bluetooth? Typical hotspots are wi-fi, and that can be as easy as turning on wi-fi (in Settings, Wi-fi - see manual or quick setup brochure) then waiting for it to find an active hotspot and plugging in any necessary password. Bluetooth is much less common. Post more info and I'll try to help more.
When i connect my samsung galaxy express to wi-fi my computer's wi-fi stops working
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
Please let me know, once you done with it.
Regards
My wifi stop working,i dont know why???
Solutions to Common Android WI-Fi ProblemsFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up. I usually fix their problem after few troubleshoots but today while I was fixing a problem on my device, I realized that it could happen to any one - even to my readers on Guiding Tech. Hence we are going to discuss four of the most common Android Wi-Fi problems and see the probable causes and solutions to them.
Android Cannot Scan a Wi-Fi Network Reason
There may be two reasons as to why your Android cannot scan a network automatically. The first reason may be that the network you are trying to connect to could be Ad-Hoc in nature. As most of the Android phones are not configured to work on Ad-Hoc networks but on access points, they don't scan them.
The second reason may be that the Wi-Fi network you are trying to connect to might be hidden for security reasons.
Solution
By default, Android does not support Ad-Hoc Wi-Fi network but many developers patch the wpa_supplicant file on Android in order for them to work. If you do a quick Google search you will be able to find if there's a fix available for your device but the fix can only be performed on a rooted phone. Furthermore, don't forget to back up your original wpa_supplicant file if at all your phones goes into foreclose or boot loops.
If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
Wi-Fi Keeps Disconnecting Frequently Reason
The most obvious reason for the problem may be with the Wi-Fi Sleep Policy which disconnects your Wi-Fi every time your Android goes to sleep to save your battery's juice.
Solution
To manage Wi-Fi Sleep Policy, open Advance Wi-Fi settings on Android and tap the option Keep Wi-Fi on during sleep. Here, check the option Always to enjoy an uninterrupted connectivity, but you will have to compensate it with your battery life.
If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
Obtaining IP Address Infinite Loop Reason
I don't know the exact reason behind this, but it might be a bug in Android. I have seen many people getting this problem, and it gets kind of annoying when the problem does not gets fixed even after restarting the device.
Solution
First of all, you must restart your Wi-Fi router and see if that helps. Many people say that resetting the phone to factory state works but that's not an appropriate solution. Wi-Fi Fixer is an amazing Android app that can help you here. The app resets your Wi-Fi system files (same as when you reinstall the Wi-Fi drivers in Windows, or you disable and enable the Wi-Fi adapter) and services and helps you to connect to the network and obtain the IP address.
Solutions to Common Android Wi-Fi Problems
Ads by Google
    wifi-router.pngFriends of mine who use an Android come over to me usually with problems related to their devices' Wi-Fi connectivity. Moreover, it's not a single isolated issue. There are all kinds of them they bring up.
    Solution
    ad-network-manually.png If the problem is with the hidden network, you can try to add the network manually. In Android Wi-Fi settings open menu and tap to add a network manually. You must enter the correct SSID and authentication type and password in order to connect to the network. If both the credentials are correct, the Android phone will be able to connect to the network.
    Solution
    Ads by Google advanced-settings.pngkeep-wifi-on.png If you are using any third-party app to save your battery, check if it's controlling your Wi-Fi and other radio services and configure accordingly.
    Solution
    wifi-fixer.png If you know the range of IP address the router is broadcasting, you may configure your Android to use static IP address while connecting to the network.
    Can't Connect to Internet using Wi-Fi Reasons
    There may be several reasons as to why you are not able to connect to the internet even when you are connected to the Wi-Fi. The reasons may be:
    • The router is not broadcasting internet services.
    • The IP address or the gateway is wrong.
    • Problem with the DNS settings.
    Solutions
    You may use another device to check if the router is actually broadcasting internet. Also you can configure the IP address, the gateway and DNS manually to connect as their might be problems with DHCP.
    Conclusion These are pretty much most of the Android problems one might encounter on his device and the probable solution one can try to fix the problem. I don't guarantee that you will fix the problem but it's a good start nonetheless. And most of the solutions should work actually.
Thanks .
Sep 03, 2013 • Cell Phones
1helpful
2answers
Wifi for my Tablet
Thank you for the Video, this made it much easier for me to determine the problem. You are correct, you have WiFi, this is not the problem, the problem is with the Tablet's WiFi Service which is freezing, thus not causing you to access WiFi.
Have you installed any new software lately? Something has broken the WiFi software on your Tablet. If you installed a new App recently, remove it to see if that new App broke your WiFi software on your Tablet. If you have not installed anything new on the Tablet maybe the manufacture downloaded an update that broke the WiFi on the Tablet. If you recently received an Software update from the manufature, let perform a Factory Resetr on the tablet to fix the issue.
2helpful
Unable to Connect to WI-FI with my Samsung Galaxy GT-19000 when scanning it states' UNABLE RO SCAN NETWORK' tried turning on& off and review settings but I'm affraid of making things worse. I have had...
I just had this same problem - I suspect it may have been a new app I installed that changed some settings.
I fixed mine by going into Settings>Mobile Network settings, then tick "Use packet data". Worth a try.
Xv6700 phone won't make calls "a wireless radio must be attached"
I HAVE THE OPPOSITE PROBLEM, I WANT WI FI TO WORK WITH OUT PHONE SERVICE ACTIVATED. IS THIS POSSIBLE?????
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
