Check the manual to find out what that code means. If you don't have the manual, go to the company web site to view the instruction manual. There you will find out what the problem is...........
Hi there
A couple of points.
Many system boxes no longer have built in speakers, and if they do they are very simple and simply used for POST errors and other alarms eg CPU fan failed, overheating etc. If there is a pattern to the beeps, you need to check against your BIOS codes to ensure nothing serious is happening.
If your system is working completely normally otherwise, then I would suspect an audio problem, which might be resolved by removing and re-installing the audio driver from the disk supplied.
Cheers
I would suggest staying on the web and doing a product search and you should be presented with suitable suppliers. Just type into your web browser 'girbau washer' and see what turns up. That's what I would do.
Sorry I can't be more helpful.
