How to enter service mode on bizhub 164 + bizhub 215
SOURCE: How to delete malfunction code c-3751 on bizhub c-252?
What error code do you get when you try to print or copy?
CAUSE: Initial settings did not take when programmed.
SOLUTION: Time and date, telephone and ADF serial numbers need to be reentered:
1. Sub-power ON g Utility/Counter g Machine Admin settings g System settings g Date and time setting g (Enter year/month/day/time) g OK g Exit g Power OFF sub-power switch.
2. Enter Service Mode g System settings g Setup date input g (Enter year/month/day) g OK.
CAUTION: DO NOT POWER OFF. Leave machine in Service Mode.
3. In the Service Mode g System settings g Telephone setting g (Enter 16-digit number) g OK. Repeat for the fax number. Set to all 9s if there is no fax number.
4. In the Service Mode g System settings g M/C serial number setting g touch ADF g (Enter ADF serial number) g OK g Power OFF sub-switch.
5. Power ON sub-switch and run copies with no security lines.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
