SOURCE: TV keeps on trying to auto tune
I would try first unplugging the set for about 30 seconds to see if that clears up the problem. If not, then it could be anything from a bad connection or component inside the set, and with it being made by a 4 letter word company, pitch it and get a different brand set. Check out epinions.com before plunking down the money on another model first. May save some headaches later.
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
SOURCE: Goodmans LD3265D1 TV won't switch on.
use a freeview box, turn the dtv off in the menu
To get it too power on press the source button a lot after a (good) few trys your get it up on another source, my own tv does this and using a freeview/freesat box makes it use-able just a pain to turn on in the first place even if you turn the dtv off in the menu
If anyone knows how to get it to turn on stright to another source would be great to know how
