Question about LG Televison & Video
My Lg tv #37lh260h keeps showing Input blocked .It wants password and I never set 1 .Help Im so frustrated
  • 2,337 Answers
Hello Lisa,
Try using the default password 0000 or if that doesn't work, go to menu, lock and see if the lock system is on.. If the lock system is on, turn it off.
Check the TV user's guide for more info.
Hope this works
Posted on Apr 15, 2018
6ya staff
SOURCE:
Lastoni Wibowo
  • 2246 Answers
SOURCE: Im trying to instal a logitech 600 remote to my LG
it set to use as output hdmi, chane setting to be a tv use your remote
Posted on Jan 22, 2011
dduncan774
David Duncan
  • 760 Answers
SOURCE: My TV is not showing
Go into your user menu and make sure the inputs are turned on. If they are, check your source and make sure it is working. You can do this buy hooking something else to your set. If you find that it is your set that is the problem, then your main board wil need to be replaced
Posted on Apr 04, 2011
Greg Le-Merton
SOURCE: i have a 26' led LG TV , and i am using a new set top box . when i am joining the tv from set top box and going in AV mode , its showing input blocked, i can not use set top box services. please h
Please provide a model number for this TV, I would have thought being an LED tv that you wouldn't be needing a set-top box as it would be digital already.
Posted on Apr 07, 2012
SD Tech
SD Tech
  • 14553 Answers
SOURCE: service menu lg 37lh260h
your best and maybe only hope is to call the hotel unit for LG (not part of the main unit) to see if they will help or refuse you.
Posted on Nov 05, 2012
gopakumarg43
  • 76204 Answers
SOURCE: How do I turn off Hotel Mode on my Lg 37LH260H T.V
Refer its user manual for details. In most cases, you might have to enter its service mode option to make it normal mode; out of Hotel mode. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Posted on Jul 26, 2014
Ive connected my vga to vga cable from my desktop pc to the rgb pc input on my lcd tv but it shows no picture. it shows windows loading but wont show my password entry or desktop page
Because your laptop needs it's display setting changing so your second monitor is active.
While on your desktop, right click once and a box will appear, choose "properties" at the bottom.
There you will see another box, choose the "settings" tab at the top right and this will show your display options.
Right click on the number two box and "attach" it.
You may also have to change the size of the display to fit your tv.
Hope this helps
Dec 01, 2013 | LG Televison & Video
Service menu lg 37lh260h
Nov 05, 2012 | LG 37lh260h 37" 1080p 1920 X 1080 20000:1...
I have a 26' led LG TV , and i am using a new set top box . when i am joining the tv from set top box and going in AV mode , its showing input blocked, i can not use set top box services. please h
Apr 07, 2012 | Televison & Video
How to reset a password
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
Sep 17, 2011 | LG 42LG50 42 in. LCD HDTV
Hi i have a dse ge6888 lcd tv and it is asking for a password a 4 digit one its never asked for a password and it is blocking g rated shows that i watch can u please tell me the override password code for...
To enter the LOCK menu, password will be requested, the default password is 6666.
The master password is 9527 and may be entered if the user set password is lost or forgotten (in order to program a new password).
Jun 21, 2011 | Televison & Video
My 32" Lg set now
Go to the menu and check you input setting . Or take the remote push the input button (tv/video)If this does not help then hook that input cable to another tv to check for signal.
Mar 01, 2011 | LG Televison & Video
LG VCR GC480W can't tune in to tv
Any vcr I know of usually is tuned through channels 3 or 4 unless they are hooked up directly by RCA patchcord. 3 pronged- 2 audio and 1 video. With the patchcord you'll be tuning through an auxilary input in the tv.
Jan 27, 2009 | LG XBR446 DVD Recorder/VCR
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Connecting LG 50PC3d to Computer
It sounds like you have the resolution of the PC set to an incompatable format for your TV.
Nov 21, 2007 | LG 50PC3D 50 in. Plasma Television
Televison & Video Logo
436 people viewed this question
Ekse
RONALD CARTER JR
