SOURCE: I have a JVC LT-23D50BK
this is not problem with your TV i think.
this can be a problem with the hardware of set top box sir
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
SOURCE: i have a jvc tv lcd model lt-42e488 the green
is a inverter control board defective, need to be replaced.
SOURCE: JVC LT-42DA8BJ
How are you connecting your laptop to the samsung TV? Is it DVI/HDMI or thru more-common S-video cable? I have successfully ported laptop screen to TV with S-Video. After you connect your S-video cable, right-click on blank desktop of laptop and bring up the Display Properties (usually the last entry on pop-up menu). Got to last tab, usually called Settings. You should see two monitors displayed on top part of this page. One of these (most likely #2) is your TV. Click on #2 monitor and check the box that reads "Extend my Windows desktop to this screen" (or words to that effect). Be sure you have the TV turned on and facing you because you may find yourself clicking on icons on the TV screen. You'll probably have to play with which is primary display because some video players have trouble playing to a secondary screen. You may also try the Fn+F8 (CRT/LCD) button on your laptop (those are the keys on my Dell). That may turn on the TV-out on the laptop. Lastly, remember that this will only get you video. You'll have to connect a 3.5 mm cable to you Line-Out port on the laptop and connect it somehow to your TV or SurroundSound speakers. There should be a audio-in port on those other devices for that. Or you can just play the sound thru your laptop speakers.
I'm not that familiar with the DVI-out but I suspect that it would work very similiarly. Good luck.
SOURCE: what do i need to connect the laptop to a JVC lt
If it is an LCD TV you can use either a Composite to VGA adapter, or simply a VGA adapter. All desktops have a VGA port (female port) and most LCD TV's have the same.
Good Luck,
NOLA Tech
Testimonial: "Fast response!! Great service."
