Radio Communications Logo
Travis Bautsch Posted on Apr 13, 2018
I have a Uniden Atlantis 295 .how in the world do you get the weather channel to work
Always starts on channel 16
This question has been around for quite awhile, but if anyone else requires the information, as best as I can tell from the owners manual (see below) on page 12, each time the radio is turned on, it starts on channel 16. I believe this to be an important feature in case the user is involved in an emergency situation.
(As a victim or as a possible rescuer.)
-Steve
http://www.uniden.com/pdf/ATLANTIS%20250om.pdf
2answers
I have an older uniden marine radio that i just bought and i am wondering how i get on the weather channels
Turn the radio on, set the radio to USA then use the up-down channel selector and scroll down to channel 1 that's it. Good luck.
2helpful
Atlantis 250 - have no squelch when unit is on. Battery is charged but can not receive or hear transmissions ie weather reports. Any suggestions?
me too. Also, transmit seems to work fine but the battery level indicator drops a lot after a few short transmissions.
Need programing instructions
try this website here it has all uniden products http://www.uniden.com/index/manuals_results.cfm?cat=3 i believe it uses the same manual as BC248CLT
Constant beep, channel number and tx flashing
Ok this problem is caused by the spring mic jack
Getting rusty
19helpful
8answers
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
Turn off power, hold down the 2, 9 & L/O buttons while turning the power back on.
2answers
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
To remove the lockout from a channel, manually
select the channel, then press Func + L/O.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
