And when I place the phone on the charger nothing happens
SOURCE: My phone will not show it charging and will not turn on, red light flashing
dear
you have mentioned that ur phone is charging and not getting on. that means ON\OFF path is having problem .due to dry solder of ON\OFF switch its happening. please resolder it and then check it
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
SOURCE: Microsoft Wireless 4000 Mouse - No Red Light on Base
The red laser light stopped working on mine and it turned out to be the connetion between the battery tray and the circuit board. There is a metal tab on the circuit board and a matching one on the battery tray. When the battery tray slides in correctly the two tabs touch and viola (!), my red laser light came back on. Maybe one tab or the other got bent when I slammed the tray in crooked when replacing a battery- who knows.
SOURCE: Samsung glyde - no response to charging
Find someone else with a glyde and ask them if you can trade them batteries for a day to see if it's a bad battery. ( you can usually buy a battery for $5 on ebay, or up to $20 in your carrier cell phone store)
If the problem follows your old battery, toss it and buy another battery.
And if neither swapping out the charger and the battert solve your problem then its the phone itself. I have called in to our cell companies before and let them know we have a phone that will not hold a charge no matter what battery or charger I use... and they usually replace free it under warranty as long as the phone is less than 12 months old, and the white squares in the battery compartment are still white. (Pink Red means oops! water got in there) and then you’re only getting them to cover replacement if you have cell phone insurance
SOURCE: Samsung Intensity Wont turn on.
More often then not its the battery even tho the battery is fully charged as it may seem. The rel test is get a new battery not your friends battery tho but a new one put it in there and let it charge. If that doe not work then the phone's logic board has been effected and it may or might not be worth reviving. But check the battery first.
Please do be considerate and leave ratings and feedback for all experts involved in helping you out today, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
