Question about Yamaha Music
Yamaha YPG-235 display froze at startup with Magix MusicMaker software. Display lights but all controls dead,
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: yamaha 9000pro froze and after restarting doesnt do anything
First thing is to Isolate the keyboard and then take out the Hard Drive and restart the keyboard. If that doesn't work then that's the first problem eliminated. You can do a Factory Reset on the keyboard. I'm not too sure on this keyboard but mostly it's Turn on the keyboard and simultaniously hold a certain button(s) or Key(s) [normally at the top end]. This info will be in the Manual.You could look at the troubleshooting page in the Manual also. Other than that at this time I can't help any further.......Good luck!
Posted on Dec 31, 2008
Fred Yearian
  • 5603 Answers
SOURCE: dead nothing on display but power supply lead
If the power supply is NOT the original one, it may be reversed polarity.
The supply should be a PA-3C with the center being "+".
Posted on Sep 23, 2009
Anonymous
SOURCE: What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Posted on Nov 08, 2009
ninimimi1
SOURCE: I have a Yamaha YPG-525. Everything is working
I have the same problem, mine is Yamaha YPG-625. This seems to be a common problem with Yamaha keyboards. I opened the 100 screws in the back, separated the main board from the display unit which is under it if you flip the keyboard upside down, to verify if there was any loose wires, nothing of the sort.
It is so frustrating, the keyboard is working fine but it is hard to navigate because the display is not functioning. Yamaha should do a recall as this is obviously something wrong with the keyboard happenning to a lot of people
Posted on Oct 15, 2010
rhodesworks
  • 3156 Answers
SOURCE: How do I adjust the contrast on the display screen of my yamaha ypg-535?
There is a contrast control knob on the rear panel of the instrument.
Posted on Oct 20, 2015
How do I download the USB driver for my Yamaha YPG-525 Portable Grand, so that it will work with Windows 10.
Windows 10 appears not to be supported on YPG525
you could try :
http://faq.yamaha.com/us/en/article/index/id/4181/?search_query=Ypg-525%20windows%207₪t_page_id=1
Jul 01, 2017 | Yamaha Full-Size Keyboard
Tip
YPG625 Humity problem
The overal sound of yamaha YPG 625 and keys operation are exellent by the price. The only problem I eperienced is the instrument operation under high humidity environment. Under this condition many keys sound loud over others, furter more with no expectation from mucisian. This problems is normal for that model because the music store change my previously YPG625 for the same problem<br /> <br /> Sometime I solve the problem to located the instrument under sun exposure and cover the keys and display to avoid direc sun exposure.<br /> <br /> Another is apply with a hair dryers over the keys. But is very disconform situation, and I dont know if the Yamaha exposed this isntrument under high humidity environment durig the product test. I has a Ymaha very low budged digital piano and Roland controller A33 in the same condition and never eperience problems, only with this model.
on Jun 16, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
Oct 20, 2015 | Yamaha YPG-535 88-Key Portable Grand Piano
Yamaha ypg 625 screen lights up, but no data
display screen might have very tightly screwd up bit loosen try for all of them
Dec 15, 2013 | Yamaha Music
Some keys not working on yamaha ypg 235
check conection betwwin keyboard to mother board
Oct 18, 2013 | Yamaha Portable Keyboard with 61...
Keys working explanation or user guide
You need to load software on your computer that contains midi sounds - sampletank, Reaktor, etc. Make sure everything is set to Midi channel 1.
Jan 20, 2013 | Alesis Q49 USB/MIDI Keyboard Controller
Rhythm accompaniment does not play. Start button flashes 3 green then 1 red. Began when someone randomly pushed number buttons on the key pad.
Do an initialization (factory reset) by holding the HIGHEST WHITE key down and turning on the power. Hold the key for an extended time until display confirms initialization complete. This will restore unit to factory defaults.
Jul 14, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
Hello, i spilt some smoothie on my Yamaha YPG-625s keys. The keys sound better now but i just want to properly clean the inside. How can i do this?
It is a lot of work to open and access the key contacts. Here is your service manual:
http://elektrotanya.com/yamaha_dgx-620_ypg-625.pdf/download.html
Scroll down to "get manual" and click on it to download. Ignore other download links on the page as they are for viewers and other software.
Jul 10, 2011 | Yamaha YPG-625 (YPG625) Digital Piano
I have a Yamaha YPG-525. Everything is working except the LCD screen. It turns on, but doesn't display anything... I had this problem once before when I didn't use the keyboard for a while, but it ended...
Jan 08, 2010 | Yamaha Full-Size Keyboard
Music Logo
114 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
