SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
SOURCE: Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
SOURCE: fwt449gfs2 washes, empties some water, does not spin, knob does not advance
There are two possible causes of the machine not going into the spin.
The first is an obstruction in the drain pump. This can be a partial block caused by a loose coin or bobby pin. The only way to clear the obstruction is to remove the lower panel at the front by removing the 2 screws at the lower edge. This will allow the front panel to drop down. You will need to unplug the machine for the naex part.
Now this will get a little messy... Be sure to have a lot of towels nearby to sop up the water. On the lower right hand side there is a pump with a black bellows attached which is also attached to the bottom of the tub. This black hose is clamped to the front of the pump if you unclamp the hose the remaining water in the system will spill out and you will have to reach inside the bellows and remove whatever obstruction is inside. some models will have a trap inside which may have to be removed from the top of the hose assembly by unscrewing the clamp on the bottom of the tub.
The hose will have to be reattached in teh reverse manner. It can be quite tricky to do so... Once the machine is back together you can test it by running a straight spin cycle, it should go into the full spin with no water in the system.
The other cause could be a faulty timer which may need to be replaced.
SOURCE: Whirpool Ultimate Care II washer Imperial Series spins at low speed
it sounds like a worn clutch.
