SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
SOURCE: change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
SOURCE: What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
