I know the seat seal is not leaking and the rubber on the shaft is not leaking. When the pump is sitting on the fan guard and the impeller is off the stainless steal back plate holds water but whit the pump assembled it leaks a lot out the seal under pressure.
SOURCE: 1988 honda cr125 water pump shaft leak
Go to the site below and download a free service manual for your bike. The manual will really help you, and it is faster than my one finger keystrokes.
http://www.carlsalter.com/motorcycle-manuals.asp
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
SOURCE: shaft seal leaks on sta rite pump?
You need to get to the shaft at the back of the motor to hold it while you use water pump pliers or the like to turn it off. It will unscrew in the regular direction but if it has a set screw to hold it in (You will find this at the center of the impeller) this will be a left hand screw so you will go clockwise to loosen it. This should get the impeller off. If not you will need to put a screwdriver in the side of the impeller and give it a hit to lossen the impeller. Good luck.
SOURCE: Leaks water out of the back
Well, I am no plumber but I would think that 108 psi is a bit high for your plumbing system. I have this pump installed in my house and have the max pressure set at 50 with a PRV on the outlet side of the pump.
SOURCE: leaking back sunroof, order new rubber seal, how
Land Rover Part # RTC 6481. I have the same issue when mine pops out of track. This part is available in UK, but I don't n=know of a US supplier.
