Washing Machines Logo
T
Theresa Forte Posted on Apr 21, 2018
Whirpool Cabrio washer - UL code, but I redistributed load & clothes still wet. What could causes wet clothes after spin cycle?
5 Related Answers
Anonymous
  • Posted on Jan 06, 2009
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Anonymous
  • 92 Answers
  • Posted on Feb 06, 2009
SOURCE: Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Anonymous
  • 277 Answers
  • Posted on Mar 02, 2009
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Anonymous
  • 240 Answers
  • Posted on Mar 14, 2009
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
richroth
Richard Roth
  • 9472 Answers
  • Posted on Sep 08, 2011
SOURCE: UL LIGHTS SHOW AT FINAL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
The image below will help you with this project. Remember to unplug the washer first.
If there is nothing like coins or socks under the basket then the problem might be the control.
Whirlpool Cabrio model WTW6200VW0 Apparently there is inherent problems with these type of washers being “OL” overload fault and “UL” unbalanced load when neither condition appears to be issue. Mine shows...
uL is displayed when the machine/motor control detects an off-balance load and remains on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the lid is opened, allowing the customer to view and redistribute the load
What does code uL mean. this comes on in the drain spin cycle
Hi, a UL error code means a load not balanced. The washer is running a load-balance correction routine. Please allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
4helpful
2answers
My cabrio waher will not spin on the last 12 min of the cycle...it displays ul everytime...it is not unlevel we have checked
My washer dose the same thing even with no clothes in it, cause i'v leaveled it and redistrbute the clothes in nothing wroks
Cabrio washer with uL code. Will not operate properly after resetting & not even with small load.
if it went thru the mini-cycle to redistribute the lad of clothes and it continues to flash uL then open the lid and manually redistribute the load,if this doesn't correct the problem,then try unplugging the unit for 15 minutes to re-set the ecu control unit and re-plug in and retry it
5helpful
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
1helpful
2answers
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
2helpful
2answers
Noisy when trying to spin. display uL instead of time remaining. Stopped, opened lid and redistributed load. Started up again. cycle continued but still displaying uL. Not sure if load still unbalanced?...
REPLACE YOUR SUSPENSION RODS. You can get them at a discount applicance parts store online for about $60. Our washer is about 8 years old and has been getting unbalanced on every load. I replaced the suspension rods tonight and and it solved the problem.
Top Washing Machines Experts
john h
