If you have no other option want to try a master reset?
Testimonial: "If its the only way to get to use my phone."
If its the only way to use my phone suppose I will have too.
This can work in 70% but notice that sometime it dont so be aware Switch off yoyr phone then do this press Volume Up + Home + Power button, until you see Samsung logo. Release held keys when the Samsung logo appears on the screen. Then select from menu "wipe data / factory reset" using Volume buttons to navigate and Power button to confirm
Let me know if its good
Thanks will try.
SOURCE: Phone lock needs unlocking - samsung g600
switch the phone on without a sim card,
type in *2767*2878# WAIT for it to reset,
once it boots up itself, the phone code is now gone,
if the phone is asking for a SIM LOCK password
then send it to someone who has the equipment to unlock it
SOURCE: i have forgotton my lock
lock screen pattern and gmail password is not related. but if you forgot the lock pattern u can reset or disable it with gmail id and password. If you draw the incorrect pattern five times you will get a message press OK. u can see a new button on screen below the pattern named "forgot pattern?". Touch this button to reset or remove the pattern with gmail id and password.
