How many different armatures would fit this model 0234-1 ser. 532c There are quite a few of model 0234-1 but with different revisions. The drill seems to have not changed. Any one know if older revision drill would cross over to newer drills within the same model?
SOURCE: Can I receive a free wiring schematic for a
yes you can, go to "milwaukeetool.com" and type in your model number but you also need the serial number, you can download the wiring and also a parts breakdown and owners manual for this tool. Let me know if you need more assistance, I worked on them for 17 years.
SOURCE: I want to know the
they make a service fixture for that BUT if you can find a thin wall open end wrench that will fit behind the chuck on the hex of the spindle you can still do it. What you will need to do is remove the left hand chuck retaining screw, put the wrench or similar item over the hex and then put the chuck key in a hole that is about a 30 degree so that you can strike it counter clockwise to remove. That chuck is on tight and there no easy way to remove it like you can do on cordless items.
