SOURCE: My 99 Camry has done
you know the thing has run 400k miles, that is 300k past it designed life. break down and buy a new fan for it, it will set you back about 60 bucks. if you can replace the resistor, you can change the fan. a new set of plugs, plug wires, and a set of tires may be warranted as well.
SOURCE: HOW DOES A DC PERMANENT MAGNET MOTOR WORKS HOW
a dc motor runs by voltage the higher the voltage the faster it spins, reversing the power and ground makes the moter fon either clockwise or counter-clockwise i hope this helps if you need more help get bak to me. also must have enough amperage to run the motor, Thanks Ray
