SOURCE: My car has a computer box problem, it does not
have you tried replacing it with an other? try one from a used one from a slavage unit, its cheeper than the dealer, when mounted check that all grounds are fasten ok.
SOURCE: black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
SOURCE: how can I test whether
You have to check You have to check the battery and charger for voltage with a volt meter. The charger should be putting out at least 14.5 volts and the battery should read 14 volts. There are metal contacks on the battery and on the charger inside the hole where you insert the battery.
SOURCE: How can I get play store on my JVC Smart TV ?
First be sure that it connected in the internet and search playtore in Google to get apk file for playstore
Did you ever manage to find a solution?
